11 Replies Latest reply on Sep 4, 2007 9:47 AM by Newsgroup_User
    Div ID
    Stevan
      I use Dreamweaver 6
      I can not find the button or link to insert a DIV ID TAG or is it a manually added item
      THXS Steve
        • 1. Re: Div ID
          Level 7
          If you are using DMX6.0, please update to DMX6.1 at your earliest
          opportunity - use the updater at the Adobe site.
          Right click on the <div> tag on the QuickTag selector bar, select Set ID,
          and select the desired ID from the list.
          Murray --- ICQ 71997575
          Adobe Community Expert
          (If you *MUST* email me, don't LAUGH when you do so!)
          http://www.dreamweavermx-templates.com - Template Triage!
          http://www.projectseven.com/go - DW FAQs, Tutorials & Resources
          http://www.dwfaq.com - DW FAQs, Tutorials & Resources
          http://www.macromedia.com/support/search/ - Macromedia (MM) Technotes
          "Stevan" <stevelindab@bellsouth.net> wrote in message
          news:fbjic3$71n$1@forums.macromedia.com...
          >I use Dreamweaver 6
          > manually added item
          > THXS Steve
          • 2. Re: Div ID
            Stevan Level 1
            I have a button called Tag chooser BUT no DIV ID there or am I missing something
            I did do the download
            Steve
            • 3. Re: Div ID
              Level 7
              news:fbjni7$cik$1@forums.macromedia.com...
              >something
              > Steve
              Set ID from the tag-chooser only works with pre-defined id's in stylesheets
              (e.g. #theID {/*styles*/}),
              Dreamweaver MX has no inspector for plain DIV tags, but you can create a
              layer which is an absolutely positioned div(Insert > Layer), use the layer
              inspector to set the ID, then remove it's style attribute, removing the
              style attribute will disable the layer inspector, to keep the layer
              inspector functioning with relatively positioned divs use the following
              code:
              <div id="myID" style="position:relative;"></div>
              Joris
              • 4. Re: Div ID
                Level 7
                >I use Dreamweaver 6
                > manually added item
                Just FYI, "ID" isn't a tag, but an attribute of a tag.
                Patty Ayers | Adobe Community Expert
                www.WebDevBiz.com
                Free Articles on the Business of Web Development
                Web Design Contract, Estimate Request Form, Estimate Worksheet
                • 5. Re: Div ID
                  Level 7
                  Good - did it take when you installed it? To see, go to the DW executable
                  file, right click, choose PROPERTIES | Version, and tell me what version
                  number you see there, please.
                  >something
                  > Steve
                  • 6. Re: Div ID
                    Stevan Level 1
                    THXS
                    Joris van Lier
                    That did it I am leaning and do not know much yet as of the correct terms
                    I can do easy things but until I run into something like this and you do a search and nothing show up due to not searching right
                    Thxs Steve
                    • 7. Re: Div ID
                      Stevan Level 1
                      6.1
                      >something
                      > Steve
                      • 8. Re: Div ID
                        Level 7
                        What are the numbers you see for "File Version", please.
                        news:fbjs4h$hft$1@forums.macromedia.com...
                        > 6.1
                        > >something
                        > > Steve
                        • 9. Re: Div ID
                          Level 7
                          news:fbjqro$g30$1@forums.macromedia.com...
                          That is so true. I've been yelled at on forums for not searching for
                          something, when I didn't know the word for what I was searching for! :-)
                          www.WebDevBiz.com
                          • 10. Re: Div ID
                            Stevan Level 1
                            www.WebDevBiz.com
                            It seems like sometimes people that post here think that everyone is a Prof designer and that is not really true. For me I only do my own two sites and there where designed in dreamweaver so i use that but never used a lot of the items that are available. SO when I run into something like above and the person who made the images for me said to
                            Wrap <div id="newletter"> and </div> around it. I did a search for that div id and nothing came up so you post and sometimes like you say people sometimes get upset .
                            But I just move on and someone always answers the question
                            Steve
                            • 11. Re: Div ID
                              Level 7
                              On Tue, 4 Sep 2007 11:26:22 -0400, "P@tty Ayers ~ACE"
                              Very true - a bit like finding the correct spelling in a dictionary !
                              ~Malcolm N....
