0 Replies Latest reply on Mar 11, 2010 2:48 AM by Giuseppe Muccioli
    Repeater with recycleChildren=true
    Giuseppe Muccioli
      Hello,
      I've a strange (for me) problem refreshing dataProvider of a Repeater component.
      I'm tying to set an Apple AddressBook's like tool to define in a form the multiplicity of a field, like the phone number.
      This is the pseudo code:
      <mx:Repeater id="rp" dataProvider="{dp}" recycleChildren=true>
           <local:MyFormItem label="{rp.currentItem.label}>
                <mx:TextInput id="ti" text="{rp.currentItem.data}"/>
           </local:MyFormItem>
      </mx:Repeater>
      Where:
      [Bindable] private var dp:ArrayCollection=new ArrayCollection([
                     {label:"Phone", data:"111111111"},
                     {label:"Phone", data:"222222222"},
                     {label:"Phone", data:"333333333"}
      This is a snapshot of what appears:
      When I click on the "+" button, what I'm hope to view is a new MyFormItem component as a bottom component, but this is the result:
      The function to add an item is like:
      dp.addItemAt({label:"New", data:""}, dp.length);
      Some note:
           - I'm using flash builder 4 beta 2 with SDK 3.5a (but this is the same with 3.4.1);
           - every MyFormItem component is positioned absolutely (the parent is a Canvas with a custom layout procedure);
           - all works well if I set the recycleChildren=false property of the Repeater, but I don't like the successive redraw;
      Any suggestion?
      Thanks a lot in advance
      -g
