5 Replies Latest reply on Mar 11, 2010 7:51 AM by KillingMedia
    How to remove the scaled images gap?
    KillingMedia Level 1
      Hi everybody,
      view this little application, which displays 4 images in 2 cols and 2 rows.
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml"
                              layout="vertical"
                              xmlns:local="*"
                              applicationComplete="onApplicationComplete()">
        <mx:Script>
              <![CDATA[
                    // creating an image, ignore that ...
                    private function onApplicationComplete():void
                          var bitmapData:BitmapData=new BitmapData(400, 200, false, 0x000000);
                          bitmapData.perlinNoise(400, 200, 4, 12345, false, false, 7, false);
                          var bitmap1:Bitmap=new Bitmap(bitmapData);
                          var bitmap2:Bitmap=new Bitmap(bitmapData);
                          var bitmap3:Bitmap=new Bitmap(bitmapData);
                          var bitmap4:Bitmap=new Bitmap(bitmapData);
                          img1.source=bitmap1;
                          img2.source=bitmap2;
                          img3.source=bitmap3;
                          img4.source=bitmap4;
        </mx:Script>
        <mx:VBox height="90%" width="90%">
            <mx:HBox height="50%" width="100%" borderStyle="solid" borderColor="0xFF0000">
                <mx:Image verticalAlign="middle" horizontalAlign="left" height="100%" width="100%" id="img1"/>
                <mx:Image verticalAlign="middle" horizontalAlign="left" height="100%" width="100%" id="img2"/>
            </mx:HBox>
            <mx:HBox height="50%" width="100%" borderStyle="solid" borderColor="0x0000FF">
                <mx:Image verticalAlign="middle" horizontalAlign="left" height="100%" width="100%" id="img3"/>
                <mx:Image verticalAlign="middle" horizontalAlign="left" height="100%" width="100%" id="img4"/>
            </mx:HBox>
        </mx:VBox>
      </mx:Application>
      These images are scalable, but they keep their aspect ratio. Now have a look at these two screens, which are made at different browserwindow-sizes:
      http://www.abload.de/image.php?img=gap34tu.png
      How can this gap inside the boxes be eliminated, so that the scalable images flow together at any window-scaling?
      Thanks a lot
        • 1. Re: How to remove the scaled images gap?
          Matt Le Fevre Level 4
          you can utilise the horizontalGap property
          for example try this:
           <mx:VBox height="90%" width="90%" horizontalGap="0">
                <mx:HBox height="50%" width="100%" borderStyle="solid" borderColor="0xFF0000" horizontalGap="0">
                </mx:HBox>
                <mx:HBox height="50%" width="100%" borderStyle="solid" borderColor="0x0000FF"  horizontalGap="0">
                </mx:HBox>
            </mx:VBox>
          That'll keep the images together horizontally until they run out of height to expand, due to scaling being turned on.
          • 2. Re: How to remove the scaled images gap?
            i dont mean the horizontalGap-property.
            Look at this screen, i have marked the space i mean with white arrows:
            http://www.abload.de/image.php?img=gapayx6.png
            • 3. Re: How to remove the scaled images gap?
              oh right sorry, mis-understood you. It'll be the maintainAspectRatio property you want to switch to false then,
              try this
                        <mx:Image verticalAlign="middle" horizontalAlign="left" height="100%" width="100%" id="img1" maintainAspectRatio="false"/>
                        <mx:Image verticalAlign="middle" horizontalAlign="left" height="100%" width="100%" id="img2" maintainAspectRatio="false"/>
                    </mx:HBox>
                        <mx:Image verticalAlign="middle" horizontalAlign="left" height="100%" width="100%" id="img3" maintainAspectRatio="false"/>
                        <mx:Image verticalAlign="middle" horizontalAlign="left" height="100%" width="100%" id="img4" maintainAspectRatio="false"/>
                    </mx:HBox>
                </mx:VBox>
              • 4. Re: How to remove the scaled images gap?
                sorry, but also dont mean the maintainAspectRatio, the images need to keep their ratio.
                The point is, i want the surrounding container to be fitted to the scaled image to remove the unused space. But i dont know how, because the 100% settings are needed for scaling.
                • 5. Re: How to remove the scaled images gap?
                  The solution is not to work with scaleContent=true.
                  I have to calculate the size of the scales images and set it manually with scaleX and scaleY. Then, there is no bounding-box surrounding and wasting space.
