I'm trying to create a pop-up window using cfwindow. The popup seems to work ok but I get this initial display of my popup form on the browser before the base form displays over it even though the cfwindow has initshow="false".
The cfwindow pop-up is in a separate file th
<cfwindow
name="emailItOpsWindow"
title="Email Window"
closable="true"
height="300"
width="300"
draggable="false"
x="100"
y="100"
resizable="true"
modal="true"
center="true"
initshow="false"
minheight="200"
minwidth="200" >
<body>
<cfform format="html">
<table>
<tr>
<td>
<cftextarea rows="3" cols="40" name="comments"></cftextarea>
</td>
</tr>
<tr>
<td colspan="2" align="right">
<cfinput name="sendEmail" type="button"
onClick="ColdFusion.Window.hide('emailItOpsWindow')">
</td>
</tr>
</cfform>
</table>
</body>
</cfwindow>
____________________
which I include wirth
<cfinclude template="emailItOps.cfm">
later I do the following ... but problem occurs before I click and activate this code
<td><input type="checkbox" name="OvrComplete"
onClick="ColdFusion.Window.show('emailItOpsWindow')" <cfif (#GetCR.Complete# EQ 1)>checked</cfif>> <font size="2" face="Arial, Helvetica, sans-serif"><b>Complete</b></font></td>
I cannot replicate that with either CF8 or CF9. Your example works fine. I get an empty page with no form controls rendered - and when I click the checkbox, the window with the form gets shown.
I suspect you have some other complex stuff on your page that messes it up. Try to comment pieces of code one by one, and see if anything makes a difference.
-Fernis
I notice that the calling page uses a target="_blank">
Could that cause the problem?
<a href="editCR.cfm?CRID=<cfoutput>#GlobalCRID#</cfoutput>" target="_blank">Edit DR</a>
Used a workaround ... put my include of the cfwindow
farther down in the html so it doesn't appear in the visible screen.
