1 Reply Latest reply on Mar 11, 2010 11:05 AM by Sean_Wilson
    Lottery Selection
    skaro666
      Hi I am relatively new to using lingo and i am having a bit of a problem
      I have created a piece of code that puts a random numbers (1 to 49) into six boxes and named num 1 to num 6 when a button is pressed
      the code for  this is as follows:
      on mouseup
      repeat with i=1 to 6
      lvno=random(49)
      Member("num"&i).text=string(lvno)
      end repeat
      end
      However this does mean that ocassionally two boxes show up the same number does anyone know how to have each box check if the others has the same number and if it does to change it to another random number.
      Thanks in advance
        • 1. Re: Lottery Selection
          Sean_Wilson Adobe Community Professional
          A simple option is to place your generated numbers into a list. Then when you get a new number, check to see whether it's already in the list and if so get one again.
           on mouseUp me
            lNumbers = []
              repeat while TRUE
                lvno=random(49)
                if lNumbers.getPos(lvno) then next repeat
                exit repeat
              end repeat
              lNumbers.append(lvno)
            end repeat
          end
