3 Replies Latest reply on Mar 11, 2010 7:28 PM by moluapple
    file damaged
      HELP ! When I tried to open my file (which I worked on this morning at home and have tried to open on 3 different Macs here at school,) it says "file is damaged and can not be opened or repaired" Someone pleeease tell me this is just a nightmare and that it can be fixed. Thanks
        • 1. Re: file damaged
          John Danek Level 4
          So, the original file is located at home?  The file you are trying to open at school may not have been saved properly.  Sometimes, when saving to a flash drive, if you remove the flash drive prematurely, it may "dump" what you saved to it.  Just a hunch.
          • 2. Re: file damaged
            Wade_Zimmerman Level 6
            I agree you cant just remove the card or disk without verifying it is either been properly ejected or burnt.
            You have to check that the a disk is properly burnt and mountable.
            You might however be able to place the file in an empty AL file.
            • 3. Re: file damaged
              moluapple Level 4
              That's not true! I have successful repaired some files before, even there is no PDF embedded.
