5 Replies Latest reply on Mar 17, 2010 5:48 PM by Zabeth69
    User Interface problem with display within design view
    salli4th
      Hello! I am using template #2 from the Adobe Developer Connection found here: http://www.adobe.com/devnet/dreamweaver/articles/dreamweaver_custom_templates.html
      When I add more than 10 navigation buttons they begin to appear to the right of the first 10 in design view.
      There is a screen grab showing the problem here: http://www.sallyaverill.com/dw_grab.html you will see in code view that it's simply a list, but it blows up in design view, pushing the content to the right and pushing a Spry accordion panel down.
      It looks and acts fine in live view and in a browser, locally and remotely, but I would like to see it properly in design view. What is causing this? Please let me know if there's more info needed. CS4, WindowsXP
      Many thanks - Sal
        • 1. Re: User Interface problem with display within design view
          Zabeth69 Level 5
          One thing to remember is that the Design View is not (as you have discovered) a WYSIWYG; it gives an approximation...and usually a pretty good one...of what your page will look like. But I have solved the problem! The stylesheet calls for the "a" tag (the link on the menu) to be floated left. This is not correct.
          First, wrap your navigation ul in a div with class="navdiv" and change your stylesheet in this way:
          .navdiv {
              width: 200px;
              height: 800px; /*This is an arbitrary height, which you may change*/
              float: left;
          /*as this next rule was applied to the ul, we will take away its float*/
          .leftnavigation {
              width: 192px;
              margin: 70px 0px 0px 0px;
              padding-left: 8px;
          /*    float: left;
          */    list-style-type: none;
          /*Then we make a group selector, adding the .leftnavigation li in order to "grab" the styling from the a tag*/
          .leftnavigation a, .leftnavigation li{
              margin-left: 0px;
              width: 156px;
              padding-left: 15px;
              padding-top: 5px;
              padding-right: 20px;
              padding-bottom: 5px;
          /*    float: left;                                    get rid of the float on the rule!
          */    color: #364957;
              font-size: 10px;
              font-weight: bold;
              font-family: Verdana, Arial, Helvetica, sans-serif;
              text-decoration: none;
              background-image: url(images/nav_normal.jpg);
              background-repeat: repeat-x;
              background-position: 0px 0px;
              border-bottom: 1px solid #999;
          /*Add the float back in, to a .leftnavigation li style selector*/
          .leftnavigation li {
              float: left;
          I have also posted this comment in the http://www.adobe.com/devnet/dreamweaver/articles/dreamweaver_custom_templates.html page, for the benefit of others reading your comment and running into the same difficulty.
          Beth
          • 2. Re: User Interface problem with display within design view
            salli4th Level 1
            It is working ok now, with one issue. The menu behavior is different and I don't know why. The whole button should darken on hover, but only the text does.
            http://www.sallyaverill.com/bom/index.html current file
            http://www.sallyaverill.com/bom/indexold/index.html previous version showing correct behavior
            I really appreciate any help because I am extremely new at building web pages. Thanks so much.
            Sal
            The css for the left navigation:
            .navdiv {
              width: 200px;
              height: 600px;
              float: left;
            .leftnavigation {
            width: 192px;
            padding-left: 8px;
            /* float: left; */
            margin-left: 0px;
            width: 171px;
            padding-left: 0px;
            padding-top: 5px;
            padding-right: 10px;
            /* float: left; */
            color: #392F9D;
            font-size: 10px;
            font-weight: bold;
            float: left;
            background: url(images/nav_normal.jpg) top left no-repeat;
            line-height:150%;
            padding-left: 10px;
            .leftnavigation a:visited{
            color: #66C;
            .leftnavigation a:hover{
            color: #ffffff;
            background-image: url(images/nav_down.jpg);
            • 3. Re: User Interface problem with display within design view
              Zabeth69 Level 5
              The reason only the text darkens on hover is because you have styled the a:hover but not the li:hover.
              Instead of
              color: #66C;
              color:  #ffffff;
              do this:
              .leftnavigation li:visited {style info here}
              and
              .leftnavigation li:hover {style info here}
              Make sure you keep them in this order! You want your pseudo-classes to come in this order:
              Link          li:link
              Visited     li:visited
              Hover     li:hover
              Active     li:active
              This still won't make your entire list item (menu item) change color, so you might also add backgrounds..right now, you are only styling the text (color styles text; background-color styles the menu item)
              Beth
              • 4. Re: User Interface problem with display within design view
                salli4th Level 1
                Beth,
                Everything's working... on to my next challenge!
                Thanks so much. You are a godsend.
                Sal
