2 Replies Latest reply on Mar 11, 2010 4:44 PM by Daniel Pride
    Basecolor uint format
    Daniel Pride Level 1
      I can't tell from the documentation on basecolor uint format...
      Is uint format the same as the old Hex Stuff?
      0x000000 as in baseColor="#514236"
      if not how do I translate real 16 bit Hex color values to whatever it is?
      Dan Pride
        • 1. Re: Basecolor uint format
          dudl123
          uint = Unsigned Integer
          In case of flash this means 32 Bit unsigned integer.
          Numbers in general not only have a value, but various representations as well.
          Example:
          The Number 10 can be written as
          0xA0 which is 8 bit hexadecimal representation
          10 which is (assumed to be) decimal representation
          012 which is assumed to be octal representation (octal = 8 based, decimal = 10 based)
          Coming back to your question:
          16 bit hex colors would normally be
          6 Bit red, 5 bit green, 5 bit blue OR
          5 bit red, 6 bit green, 5 bit blue OR
          5 bit red, 5 bit green, 6 bit blue
          Thus I assume you mean 32 bit hex colors, as #514236 is the default CSS way of writing down 32 bit hex colors (24 bit in fact, as the other 8 bit would be alpha, but let's say you're talkin about 32 bit colors)
          Thus:
          "Is uint format the same as the old Hex Stuff?"
          0x514236 can be said to equal #514236
          Easy enough?
          Conversion would be as follows to other formats:
          0x514236 = 6 + 3*16 + 2 * 16^2 + 4*16^3 + 1*16 ^4 + 5*16 ^5 = your real color number as you would write it as a decimal figure
          as well as
          5*16 +1 = Red portion, ranging from 0-255
          4*16+2 = Green portion, ranging from 0-255
          3*16+6 = Blue portion, ranging from 0-255
          Hope that answers your question.
          • 2. Re: Basecolor uint format
            Got it.
            Format as same old Hex stuff
            Dan
