0 Replies Latest reply on Oct 2, 2007 2:10 PM by Khephera
    Dreamweaver Vertical Spry Menu Problem in IE7
    Khephera
      I just finished setting up a vertical, 3-level spry menu in Dreamweaver CS3, and when I preview it in IE7, several pixels have been added in between the buttons, which spreads the menu out and looks terrible. The problem disappears after I clear the ActiveX warning, and it doesn't occur in FF. Could someone please tell me how to fix this??
      Here's my SpryMenuBarVertical.css file:
      @charset "UTF-8";
      /* SpryMenuBarVertical.css - Revision: Spry Preview Release 1.4 */
      /* Copyright (c) 2006. Adobe Systems Incorporated. All rights reserved. */
      LAYOUT INFORMATION: describes box model, positioning, z-order
      /* The outermost container of the Menu Bar, a fixed width box with no margin or padding */
      ul.MenuBarVertical
      margin: 0;
      padding: 0;
      list-style-type: none;
      font-size: 0.8em;
      cursor: default;
      width: 150px;
      /* Set the active Menu Bar with this class, currently setting z-index to accomodate IE rendering bug: http://therealcrisp.xs4all.nl/meuk/IE-zindexbug.html */
      ul.MenuBarActive
      z-index: 1000;
      /* Menu item containers, position children relative to this container and are same fixed width as parent */
      ul.MenuBarVertical li
      margin: 0;
      padding: 0;
      font-size: 100%;
      position: relative;
      text-align: left;
      cursor: pointer;
      width: 150px;
      /* Submenus should appear slightly overlapping to the right (95%) and up (-5%) with a higher z-index, but they are initially off the left side of the screen (-1000em) */
      ul.MenuBarVertical ul
      margin: -5% 0 0 95%;
      padding: 0;
      font-size: 100%;
      position: absolute;
      z-index: 1020;
      cursor: default;
      left: -1000em;
      top: 0;
      /* Submenu that is showing with class designation MenuBarSubmenuVisible, we set left to 0 so it comes onto the screen */
      ul.MenuBarVertical ul.MenuBarSubmenuVisible
      left: 0;
      /* Menu item containers are same fixed width as parent */
      ul.MenuBarVertical ul li
      background-image:url(../images/topnav-up-165.gif);
      background:#FFFFFF;
      DESIGN INFORMATION: describes color scheme, borders, fonts
      /* Menu items are a light gray block with padding and no text decoration */
      ul.MenuBarVertical a
      display: block;
      cursor: pointer;
      background-color: #FFFFFF;
      background-image:url(../images/topnav-up.gif);
      padding: 0.3em 0.3em;
      color: #333;
      text-decoration: none;
      /* Menu items that have mouse over or focus have a blue background and white text */
      ul.MenuBarVertical a:hover, ul.MenuBarVertical a:focus
      color: #333;
      /* Menu items that are open with submenus are set to MenuBarItemHover with a blue background and white text */
      ul.MenuBarVertical a.MenuBarItemHover, ul.MenuBarVertical a.MenuBarItemSubmenuHover, ul.MenuBarVertical a.MenuBarSubmenuVisible
      color: #333;
      SUBMENU INDICATION: styles if there is a submenu under a given menu item
      /* Menu items that have a submenu have the class designation MenuBarItemSubmenu and are set to use a background image positioned on the far left (95%) and centered vertically (50%)*/
      background-image: url(../images/topnav-up.gif);
      background-repeat: no-repeat;
      background-position: 95% 50%;
      background-color: #038203;
      border-bottom-width: 2px;
      border-bottom-style: solid;
      border-bottom-color: #666666;
      border-top-width: 2px;
      border-top-color: #FFFFFF;
      border-right-width: 2px;
      border-left-width: 2px;
      border-top-style: solid;
      border-right-style: solid;
      border-left-style: solid;
      border-right-color: #666666;
      border-left-color: #FFFFFF;
      /* Menu items that are open with submenus have the class designation MenuBarItemSubmenuHover and are set to use a "hover" background image positioned on the far left (95%) and centered vertically (50%) */
      background-image: url(../images/topnav-dn.gif);
      background-position: 0% 50%;
      BROWSER HACKS: the hacks below should not be changed unless you are an expert
      /* HACK FOR IE: to make sure the sub menus show above form controls, we underlay each submenu with an iframe */
      ul.MenuBarVertical iframe
      position: absolute;
      z-index: 1010;
      /* HACK FOR IE: to stabilize appearance of menu items; the slash in float is to keep IE 5.0 from parsing */
      @media screen, projection
      ul.MenuBarVertical li.MenuBarItemIE
      display: inline;
      f\loat: left;
      background: #FFF;
