2 Replies Latest reply on Mar 12, 2010 2:48 AM by PDL_AGH
    When is a HTTPService calling the result method?
    PDL_AGH
      Hello,
      I am using several HTTPServices, that work but are called through mx: components.
      I am using this HTTPService to load some XML in exactly the same manner, exept I try to access the resulting XML directly without calling any component:
          <mx:HTTPService id="serviceRuleTemplate"
              resultFormat="e4x"
              url="{'http://somehost:8080/RestfullMiddleware/rule-templates/'+sRuleTempPath}"
              result="ruleTemplateResultHandler(event);"
              fault="collectionFaultHandler(event);"/>
         [Bindable]
         private var xmlRuleTemplate:XML;
         // Result handler - gets called after XML is loaded.
         private function ruleTemplateResultHandler(event:ResultEvent):void{
              xmlRuleTemplate = event.result as XML;
      Later in the code i set the url variable and I call the service:
        sRuleTempPath = event.target.label;
        serviceRuleTemplate.send();
      Yet when I check the value of xmlRuleTemplate immediatly after the send(), it shows as null.
      Is there something more I need to add for the result method (ruleTemplateResultHandler) to be called?
      All the best,
      Pierre
