1 Reply Latest reply on Mar 12, 2010 6:08 AM by levancho
    Array or ArrayCollection
    JockMahon
      Should i always use arrayCollection instead of an array or is it some times better to use an array
      for example in the case where i just want a collection of values and i know that i wont have to do any sorting or anything else for example its just been used to send data to a remote service like cf
      Also is it bad practice to use the Object data type
      so for example if i want to pass data to cf and i want to pass an id and a collection of sub ids
      so i would create a Object
      so
      var myObj:Object = new Object();
      myObject["cartID"] = 8;
      myObject["cartItems"] = new Array()
      i know some of u will suggest creating a VO but to me this seams like such overkill
        • 1. Re: Array or ArrayCollection
          levancho Level 3
          ArrayCollection is more expensive than Array, and BTW you can do sorting on Array too,
          if you do not want Events when items in array change,fancy cursor serching etc ..  I would definately stay away from ArrayCollection simply because its just a wrapper around Array, anyways so you may as well use Array directly.
          but when you deal with RemoteObjects etc ... most of the times yo will have to deal with ArrayCollections.
