4 Replies Latest reply on Mar 12, 2010 7:17 PM by apemonster
    How do I stop Dreamweaver from downloading images?
    apemonster
      When I open a web page which has an image stored on a website (not on local  disk) like <img src="http://www...">, Dreamweaver reaches out and downloads the image to displays it in Design view. Sometimes I have  other applications using up all my bandwidth and DW causes problems. How do  I stop it from downloading images?
        • 1. Re: How do I stop Dreamweaver from downloading images?
          370H55V Level 4
          I hope I understand this correctly.
          Dreamweaver doesn't initiate downloads on it's own. Your browser (or a  plug in) may be set to "dump" all image files from any site you visit  and you will need to look at disabling that first.
          If you have Dreamweaver set as the default application to open and edit images, once the browser or plug in downloads them, DW is opening them per instructions from the OS settings.
          You need to change this in your OS.
          Windows: Right click any picture on your harddrive, select Properties.
                           Change "Open With" to something other than Dreamweaver.
                           Click Apply and OK
          Mac: Right click any picture on the hard drive and select Get Info.
                  Under the Open With drop down, choose another application besides Dreamweaver, and then click Apply to all from the button drop down at the bottom of the window.
                   Close the info windows when it finishes applying.
          If you have local pages linked to someone else's pictures online... stop it. It's commonly called bandwidth theft and most people don't like it.
          If all esle fails, try resetting your preferences in Dreamweaver to defaults.
          • 2. Re: How do I stop Dreamweaver from downloading images?
            bregent Most Valuable Participant
            Make sure you have Display External Files disabled.
            • 3. Re: How do I stop Dreamweaver from downloading images?
              apemonster Level 1
              Thanks a lot for your reply! It turns out 'Display external files' is what I was looking for.
              • 4. Re: How do I stop Dreamweaver from downloading images?
                apemonster Level 1
                Thank you for the correct answer. I really appreciate the help!
