1 Reply Latest reply on Mar 12, 2010 8:57 AM by Flex harUI
    mx.controls.menu - set position of submenu flush with parent
    jpdev77sa
      My boss has issues with the Flex Menu control and it's submenu's being positioned slighty down and overlapping to the parent Menu. I have been able to change the position by extending the Menu class, but now the submenu's don't hide - they stick around when they should hide on parent item rollover or document click... anyone got a fast fix for this? I am still learning the basics, so any help with be appreciated.
      Thanks in advance.
      Custom Menu code attached: (scuse the spaced out code)
      package
      import mx.controls.Menu;
      import mx.core.mx_internal;
      import flash.display.DisplayObjectContainer;
      import mx.controls.listClasses.IListItemRenderer;
      import mx.core.Application;
      import mx.controls.menuClasses.IMenuItemRenderer;
      import mx.managers.PopUpManager;
      import flash.geom.Point;
      import flash.display.DisplayObject;
      import flash.geom.Rectangle;
      import flash.utils.clearInterval;
      use namespace mx_internal;
      public class CustomMenu extends Menu
      private var isDirectionLeft:Boolean = false;
      private var subMenu:Menu;
      public function CustomMenu()
      super();
      public static function createMenu(parent:DisplayObjectContainer, mdp:Object, showRoot:Boolean = true):CustomMenu
      var menu:CustomMenu = new CustomMenu();
      menu.tabEnabled =
      false;
      menu.owner = DisplayObjectContainer(Application.application);
      menu.showRoot = showRoot;
      popUpMenu(menu, parent, mdp);
      return menu;
      override mx_internal function openSubMenu(row:IListItemRenderer):void
      supposedToLoseFocus =
      true;
      var r:Menu = getRootMenu();
      var menu:CustomMenu;
      // check to see if the menu exists, if not create it
      if (!IMenuItemRenderer(row).menu)
      menu =
      new CustomMenu();
      menu.parentMenu =
      this;
      menu.owner =
      this;
      menu.dataDescriptor = r.dataDescriptor;
      menu.styleName = r;
      menu.labelField = r.labelField;
      menu.labelFunction = r.labelFunction;
      menu.iconField = r.iconField;
      menu.iconFunction = r.iconFunction;
      menu.itemRenderer = r.itemRenderer;
      menu.rowHeight = r.rowHeight;
      menu.scaleY = r.scaleY;
      menu.scaleX = r.scaleX;
      // if there's data and it has children then add the items
      if (row.data &&
      _dataDescriptor.isBranch(row.data) &&
      _dataDescriptor.hasChildren(row.data))
      menu.dataProvider = _dataDescriptor.getChildren(row.data);
      menu.sourceMenuBar = sourceMenuBar;
      menu.sourceMenuBarItem = sourceMenuBarItem;
      IMenuItemRenderer(row).menu = menu;
      PopUpManager.addPopUp(menu, r,
      false);
      else
      //commented out can't resolve Implicit coercion error
      //menu = IMenuItemRenderer(row).menu;
      var _do:DisplayObject = DisplayObject(row);
      var sandBoxRootPoint:Point = new Point(0,0);
      sandBoxRootPoint = _do.localToGlobal(sandBoxRootPoint);
      // when loadMovied, you may not be in global coordinates
      if (_do.root) //verify this is sufficient
      sandBoxRootPoint = _do.root.globalToLocal(sandBoxRootPoint);
      // showX, showY are in sandbox root coordinates
      var showY:Number = sandBoxRootPoint.y;
      var showX:Number;
      if (!isDirectionLeft)
      showX = sandBoxRootPoint.x + row.width+10;
      else
      showX = sandBoxRootPoint.x - menu.getExplicitOrMeasuredWidth();
      // convert to global coordinates to compare with getVisibleApplicationRect().
      // the screen is the visible coordinates of our sandbox (written in global coordinates)
      var screen:Rectangle = systemManager.getVisibleApplicationRect();
      var sbRoot:DisplayObject = systemManager.getSandboxRoot();
      var screenPoint:Point = sbRoot.localToGlobal(new Point(showX, showY));
      // do x
      var shift:Number = screenPoint.x + menu.getExplicitOrMeasuredWidth() - screen.right;
      if (shift > 0 || screenPoint.x < screen.x)
      // if we want to ensure our parent's visible, let's
      // modify the shift so that we're not just on-screen
      // but we're also shifted away from our parent.
      var shiftForParent:Number = getExplicitOrMeasuredWidth() + menu.getExplicitOrMeasuredWidth();
      // if was going left, shift to right. otherwise, shift to left
      if (isDirectionLeft)
      shiftForParent *= -1;
      showX = Math.max(showX - shiftForParent, 0);
      // now make sure we're still on-screen again
      screenPoint =
      new Point(showX, showY);
      screenPoint = sbRoot.localToGlobal(screenPoint);
      // only shift if greater our position + width > width of screen
      shift = Math.max(0, screenPoint.x + width - screen.right);
      showX = Math.max(showX - shift, 0);
      menu.isDirectionLeft =
      this.x > showX;
      // now do y
      shift = screenPoint.y + height - screen.bottom;
      if (shift > 0 || screenPoint.y < screen.y)
      showY = Math.max(showY - shift, 0);
      menu.show(showX, showY);
      subMenu = menu;
      clearInterval(openSubMenuTimer);
      openSubMenuTimer = 0;
