2 Replies Latest reply on Oct 3, 2007 9:10 AM by Coldstream
    Tag missing
    Coldstream Level 1
      I am trying to update my template and getting an error "There is an error at ine 62 of "C:........: Unbalanced body tag"
      I can't seem what I have missed, or someone else deleted out by mistake (I am not the only one using this site)
      Help greatly appreciated.
        • 1. Re: Tag missing
          Level 7
          Fix these "errors "and see
          Validation Output: 11 Errors
          Line 5, Column 30: required attribute "TYPE" not specified.
          <script language='JavaScript'>?
          The attribute given above is required for an element that you've used, but
          you have omitted it. For instance, in most HTML and XHTML document types the
          "type" attribute is required on the "script" element and the "alt" attribute
          is required for the "img" element.
          Typical values for type are type="text/css" for <style> and
          type="text/javascript" for <script>.
          Line 18, Column 30: required attribute "TYPE" not specified.
          <script language="JavaScript">?
          Line 184, Column 57: end tag for "DIV" omitted, but its declaration does
          not permit this.
          </table></td></tr></table></div></td>?
          You forgot to close a tag, or
          you used something inside this tag that was not allowed, and the validator
          is complaining that the tag should be closed before such content can be
          allowed.
          The next message, "start tag was here" points to the particular instance of
          the tag in question); the positional indicator points to where the validator
          expected you to close the tag.
          Line 71, Column 7: start tag was here.
          <div align="center"> Line 195, Column 49: required attribute "ALT"
          not specified.
          src="../images/title.gif" width="800" height="38"></div></td>?
          Line 209, Column 68: required attribute "ALT" not specified.
          ./images/birdanimation.gif" width="58" height="70"></div></td>?
          Line 222, Column 34: end tag for element "A" which is not open.
          <td><div align="center"></a>?
          The Validator found an end tag for the above element, but that element is
          not currently open. This is often caused by a leftover end tag from an
          element that was removed during editing, or by an implicitly closed element
          (if you have an error related to an element being used where it is not
          allowed, this is almost certainly the case). In the latter case this error
          will disappear as soon as you fix the original problem.
          If this error occurred in a script section of your document, you should
          probably read this FAQ entry.
          Line 223, Column 11: end tag for element "NOSCRIPT" which is not open.
          </noscript>?
          Line 227, Column 9: end tag for element "TD" which is not open.
          </td>?
          Line 228, Column 7: end tag for element "TR" which is not open.
          </tr>?
          Line 229, Column 8: end tag for element "TABLE" which is not open.
          </table>?
          Line 235, Column 7: end tag for "SCRIPT" omitted, but its declaration does
          not permit this.
          </body>?
          allowed.
          Line 232, Column 1: start tag was here.
          <script type="text/javascript">? Top
          "Coldstream" <webforumsuser@macromedia.com> wrote in message
          news:fdu1tk$5kc$1@forums.macromedia.com...
          > is
          > am
          • 2. Re: Tag missing
            Coldstream Level 1
            Many thanks, I have fixed the problem with your guidance... the part about::::
            </noscript>?
            Was the fix. !
