0 Replies Latest reply on Mar 12, 2010 6:37 AM by Carol L. Frampton
    [svn:fx-4.x] 14727: Add missing selectors for air in MXFTEText.css.
    Carol L. Frampton Level 2
      Revision: 14727
      Revision: 14727
      Author:   cframpto@adobe.com
      Date:     2010-03-12 06:36:58 -0800 (Fri, 12 Mar 2010)
      Log Message:
      Add missing selectors for air in MXFTEText.css.   layoutDirection=rtl didn?\226?\128?\153t work in WindowedApplication if the width wasn?\226?\128?\153t explicitly set. WindowedApplication was using the internal _width variable in UIComponent rather than the setter so the mirroring transformation was being applied with a width of 0 ?\226?\128?\147 hence a blank screen.
      QE notes:
      Doc notes: None
      Bugs: SDK-25829, SDK-25735
      Reviewed By: Jason
      Tests run: checkintests
      Is noteworthy for integration: No
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-25829
          http://bugs.adobe.com/jira/browse/SDK-25735
      Modified Paths:
          flex/sdk/branches/4.x/frameworks/projects/airframework/src/mx/core/WindowedApplication.as
          flex/sdk/branches/4.x/frameworks/projects/spark/MXFTEText.css
