0 Replies Latest reply on Mar 12, 2010 8:03 AM by Carol L. Frampton
    [svn:fx-4.x] 14730: Reverse part of change 14649 which attempted to make sure checkmarks were always left to right .
    Carol L. Frampton Level 2
      Revision: 14730
      Revision: 14730
      Author:   cframpto@adobe.com
      Date:     2010-03-12 08:03:30 -0800 (Fri, 12 Mar 2010)
      Log Message:
      Reverse part of change 14649 which attempted to make sure checkmarks were always left to right.  Setting the layoutDirection on the CheckBox style is not correct since the text that goes with the CheckBox should be mirrored if rtl.  The actual check mark is a path buried in the skin.
      Modified Paths:
          flex/sdk/branches/4.x/frameworks/projects/framework/defaults.css
          flex/sdk/branches/4.x/frameworks/projects/spark/defaults.css
