4 Replies Latest reply on Mar 16, 2010 8:55 PM by PhyllisCaro2010
    Add/Remove instance manager issues
    BCangelosi Level 1
      My add instance button is working as intended.
      The remove instance button is working, but not as I would like it to. The instance it removes is not necessarily the last instance added, as I would like. When "clicked" it removes the second instance listed. This is a problem when you add 5 or so instances, and need to remove the last one, and end up having to remove all of them because removing the #2 instance just messed up the order of instances.
      If this is not making sense I can show you what I'm referring to by uploading/sending interested parties the form.
      Here is the "click" event javascript code. I adopted the code from the remove instance manager example, maybe I did not convert it correctly to my form. Not sure why it deletes from the first instance down, instead of last instance up. Any help is appreciated.
      var nNumSub = 0;
      var nSubLength = Subform1.nodes.length;
      for (var nCount = 0; nCount < nSubLength; nCount ++)  {
           if (Subform1.nodes.item(nCount).className == "subform"  {
                nNumSub = nNumSub + 1;
      nNumSub = nNumSub - 1;
      if (nNumSub < 1)  {
          xfa.host.messageBox("The minimum allowable number of subforms is 1. You cannot remove any more subforms.", "Warning", 3);
      else {
           Subform1.Subform2.SubformImpression.instanceManager.removeInstance(nNumSub);
      Thank you,
      B
        • 1. Re: Add/Remove instance manager issues
          pguerett Level 6
          If you want to remove the last one why not use the count method on the instance Manager. This will give you a count of subforms that are displayed (it is 1 based), then subtract 1 to get the instance number for the last subform.
          nNumSub =  Subform1.Subform2.SubformImpression.instanceManager.count
          Paul
          • 2. Re: Add/Remove instance manager issues
            BCangelosi Level 1
            That script does nothing as a replacement script or added to my original script.
            It still deletes instances starting at the top.
            Perhaps I missed something.
            EDIT: Added the -1 to the end of it and worked perfectly when added in parenthesis to my original script.
            Thanks again Paul.
            • 3. Re: Add/Remove instance manager issues
              Shailevit
              Paul,
              So I want to do the same thing, but my instance manager set-up is much simpler:
              form1.QuickNoteGathering.Data.Button1::click - (JavaScript, client)
              Data.Info.instanceManager.addInstance(1);
              So what code would I use to have a button that removes the last instance added?
              Also, I want the instances to continue on to several pages if needed (i.e.: my outlay is just a small sample and one can add as many additional information layers as they need). But it all goes awray as it comes to the buttom of the first page. So I can I assure that as you click the add additional info, it will persist to as many pages as needed?
              Thanks. I can send you the form if you need me too, since there is no upload anymore to this forum.
              thanks
              Shai
              • 4. Re: Add/Remove instance manager issues
                PhyllisCaro2010
                Paul has helped me with issue. Here's the code.
                Table1.detail.instanceManager.removeInstance(Table1.detail.instanceManager.count -1)
                To make your table continues to second page, Make sure your form is Dynamic and set to Flowed.
