6 Replies Latest reply on Mar 13, 2010 9:19 AM by C55279
    Reader took over computer
    C55279 Level 1
      I just had the experience of Adobe Reader taking over the entire computer - assuming ownership over virtually every program, including Task Manager.  It happened when I downloaded and opened (rather, tried to open) a PDF receipt for a purchase I made.  It took several restarts before I was able to get to the point where I could even uninstall the program and regain access to the computer - even in Safe Mode I was unable to uninstall it.  The only information I gather from Event Viewer appears to be  "Audit events have been dropped by the transport. 0,"  that plus the host of difficulties caused by reader trying to run a large number of programs that it was never intended to run.  Quite frustrating!!   I have never experienced this kind of problem before, is there some way  to record the computers internal state of affairs while this is going  on?
        • 1. Re: Reader took over computer
          C55279 Level 1
          I'd like to add that when I try to install reader now, it again takes over most of the programs on the computer (the icons change to the Reader Icon).  The Event Viewer shows nothing unusual, but I'm at least able to uninstall Reader and continue using the computer.  The computer is a Dell XPS M1530, running Windows 7 Home Premium.  Microsoft Security Essentials found no problems on a quick scan just now, nor on the regularly scheduled one this morning;  I am currently doing the full scan...
          • 2. Re: Reader took over computer
            pwillener Level 8
            We have seen similar situations on Vista in the past, but we have never been able to figure out what causes it, or how to resolve it.
            Could you do the following (when Adobe Reader is installed): open a command prompt window and type
            assoc .exe
            What reply do you get from this?
            • 3. Re: Reader took over computer
              C55279 Level 1
              Unfortunately, when Reader is installed it takes ownership of the command
              prompt as well.  I get the error message to the effect of: This file doesn't
              have any valid program associated with it...  This message being in a window
              on top of a blank Reader window.  I tried to run the command prompt by
              mousing to the icon in Accessories; by typing in "Command" and choosing
              Command Prompt from the list, by typing cmd.exe in the search box on the
              Start menu, and also by typing in cmd.exe from the Run command line, all
              with the same result.   Same results from typing in assoc.exe in the Start Menu search box,  and the Run command line, etc. as above.
              However, I am able to right click on any Icon that
              has been replaced by the Reader Icon and look at the properties. In every
              case the program associated and the path to it are correct, even though
              clicking on the icon produces the above error message with the blank Reader
              window.
              Possibly related: when I tried to download a new version of Reader, to
              reduce the possibility that the install package had gotten some sort of
              malware, there were problems with Firefox v3.6 regarding installing a
              missing
              plug-in called gp.xpi.  Firefox said that I needed this plug-in to display
              all the content on the page, and initially didn't allow me to download
              Reader.  The instructions for Firefox users showed screens that I never saw
              and was unable to even find, rummaging around through the Options menus.
              After I attempted (unsuccessfully) to install that plug-in I was able to
              download Reader without a problem.  This happened last time I upgraded
              Reader, but that time I switched to IE browser and downloaded from there.  I
              vaguely recall there being some message to the effect that gp.xpi could not
              be located, near the start of the current fiasco.  Sorry to be so vague
              here.
              I note that other users have had problems installing this plug-in using
              Windows XP and Firefox 3.0, so this is probably a Firefox issue and may be
              unrelated to the problem at hand.
              • 4. Re: Reader took over computer
                Unclaimed
                Same here under XP Pro SP3; couldn't even boot the machine, as Reader tried to open all the processes and prevented them loading normally!
                If you need a pdf reader anytime soon, you might consider using Foxit.   It works perfectly with Firefox 3.6.
                This reader 9.3 is the crappiest piece of software engineering I've seen in a long time.  Just look at all the different issues in the forums.
                Really, Adobe, get your collective heads out.
                • 5. Re: Reader took over computer
                  ronamater60 Level 1
                  and Adobe personnel can't wait to fob you off to this forum which is trail
                  and error
                  • 6. Re: Reader took over computer
                    C55279 Level 1
                    Thanks! Foxit takes care of the need for Reader to access my PDF documents
                    quite nicely.
                    If Adobe could use further information to correct the problem, here may be
                    another clue on the Reader issue: the error message that is generated after
                    Reader takes over all, or almost all (?) .exe programs is "This file does
                    not have a program associated with it for performing this action. Please
                    install a program or, if one is already installed, create an association in
                    the Default Programs control panel."  The header on this box, which I will
                    try to include as a jpeg attachment, reads: "C:\Program Files\Adobe\Reader
                    9.0\Eula.exe"  It may be worth noting that although the Lightroom icon on
                    the Quick start bar visible in the picture has not been replaced by the
                    Reader icon, Reader still tries to open the program.
