0 Replies Latest reply on Mar 12, 2010 3:23 PM by kevinklin
    [svn:fx-4.x] 14741: Adding ILayoutDirectionElement to address issues with non-styled components such as embedded bitmaps .
    kevinklin Adobe Employee
      Revision: 14741
      Revision: 14741
      Author:   klin@adobe.com
      Date:     2010-03-12 15:23:40 -0800 (Fri, 12 Mar 2010)
      Log Message:
      Adding ILayoutDirectionElement to address issues with non-styled components such as embedded bitmaps. Also, addressed issues with changing layoutDirection at runtime.
      -Added ILayoutDirectionElement.as with the layoutDirection property and invalidateLayoutDirection(). I took them out of IVisualElement.
      -Moved the mirroring code from FlexBitmap to BitmapAsset as well as SpriteAsset. Also, implemented ILayoutDirectionElement in both.
      -Addressed issues with layoutDirection changing at runtime by adding logic in UIComponent and Container to call invalidateLayoutDirection() on all of their ILayoutDirectionElement children.
      -Updated various other components to use the new interface.
      -Updated the dependency checker.
      QE notes: No
      Doc notes: No
      Bugs: SDK-25656, SDK-25685, SDK-25726, SDK-25758 , SDK-25776 , SDK-25784 , SDK-25791, SDK-25806
      Reviewer: Jason, Carol
      Tests run: checkintests
      Is noteworthy for integration: No
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-25656
          http://bugs.adobe.com/jira/browse/SDK-25685
          http://bugs.adobe.com/jira/browse/SDK-25726
          http://bugs.adobe.com/jira/browse/SDK-25758
          http://bugs.adobe.com/jira/browse/SDK-25776
          http://bugs.adobe.com/jira/browse/SDK-25784
          http://bugs.adobe.com/jira/browse/SDK-25791
          http://bugs.adobe.com/jira/browse/SDK-25806
      Modified Paths:
          flex/sdk/branches/4.x/frameworks/projects/framework/src/mx/core/BitmapAsset.as
          flex/sdk/branches/4.x/frameworks/projects/framework/src/mx/core/Container.as
          flex/sdk/branches/4.x/frameworks/projects/framework/src/mx/core/FlexBitmap.as
          flex/sdk/branches/4.x/frameworks/projects/framework/src/mx/core/IVisualElement.as
          flex/sdk/branches/4.x/frameworks/projects/framework/src/mx/core/LayoutDirection.as
          flex/sdk/branches/4.x/frameworks/projects/framework/src/mx/core/SpriteAsset.as
          flex/sdk/branches/4.x/frameworks/projects/framework/src/mx/core/UIComponent.as
          flex/sdk/branches/4.x/frameworks/projects/framework/src/mx/managers/DragManagerImpl.as
          flex/sdk/branches/4.x/frameworks/projects/spark/src/spark/core/SpriteVisualElement.as
          flex/sdk/branches/4.x/frameworks/projects/spark/src/spark/primitives/supportClasses/Graph icElement.as
          flex/sdk/branches/4.x/tools/dependencychecker/frameworkSwcExceptionsList.txt
      Added Paths:
          flex/sdk/branches/4.x/frameworks/projects/framework/src/mx/core/ILayoutDirectionElement.a s
