0 Replies Latest reply on Mar 12, 2010 3:31 PM by Chet Haase
    [svn:fx-trunk] 14743:
    Chet Haase
      Revision: 14743
      Revision: 14743
      Author:   chaase@adobe.com
      Date:     2010-03-12 15:30:57 -0800 (Fri, 12 Mar 2010)
      Log Message:
      QE notes: spark/effects/Resize/Controls/Resize_Controls_Button_FromTo needs to be fixed to reflect the new behavior; effects that set playheadTime >= the effect duration no longer automatically dispatch an effectEnd event. Also, basictests EasingTests was updated to reflect new (correct) behavior.
      Doc notes: none
      Bugs: sdk-25352, sdk-25270, sdk-25269
      Reviewer: Jason (+Ely for sdk-25352's AnimateTransformInstance)
      Tests run: checkintests, Mustella mx/effects/Parallel|Sequence, spark/effects
      Is noteworthy for integration: no
      Ticket Links:
          http://bugs.adobe.com/jira/browse/sdk-25352
          http://bugs.adobe.com/jira/browse/sdk-25270
          http://bugs.adobe.com/jira/browse/sdk-25269
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/framework/src/mx/effects/effectClasses/CompositeEffect Instance.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/effects/effectClasses/SequenceInstanc e.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/animation/Animation.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/supportClasses/AddActionInstan ce.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/supportClasses/AnimateTransfor mInstance.as
          flex/sdk/trunk/frameworks/tests/basicTests/spark/scripts/EasingTestScript.mxml
