Revision: 14744
Revision: 14744
Author: klin@adobe.com
Date: 2010-03-12 15:33:39 -0800 (Fri, 12 Mar 2010)
Log Message:
Merge revision 14741 from 4.x to trunk.
Adding ILayoutDirectionElement to address issues with non-styled components such as embedded bitmaps. Also, addressed issues with changing layoutDirection at runtime.
-Added ILayoutDirectionElement.as with the layoutDirection property and invalidateLayoutDirection(). I took them out of IVisualElement.
-Moved the mirroring code from FlexBitmap to BitmapAsset as well as SpriteAsset. Also, implemented ILayoutDirectionElement in both.
-Addressed issues with layoutDirection changing at runtime by adding logic in UIComponent and Container to call invalidateLayoutDirection() on all of their ILayoutDirectionElement children.
-Updated various other components to use the new interface.
-Updated the dependency checker.
QE notes: No
Doc notes: No
Bugs: SDK-25656, SDK-25685, SDK-25726, SDK-25758 , SDK-25776 , SDK-25784 , SDK-25791, SDK-25806
Reviewer: Jason, Carol
Tests run: checkintests
Is noteworthy for integration: No
Ticket Links:
http://bugs.adobe.com/jira/browse/SDK-25656
http://bugs.adobe.com/jira/browse/SDK-25685
http://bugs.adobe.com/jira/browse/SDK-25726
http://bugs.adobe.com/jira/browse/SDK-25758
http://bugs.adobe.com/jira/browse/SDK-25776
http://bugs.adobe.com/jira/browse/SDK-25784
http://bugs.adobe.com/jira/browse/SDK-25791
http://bugs.adobe.com/jira/browse/SDK-25806
Modified Paths:
flex/sdk/trunk/frameworks/projects/framework/src/mx/core/BitmapAsset.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/core/Container.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/core/FlexBitmap.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/core/IVisualElement.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/core/LayoutDirection.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/core/SpriteAsset.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/core/UIComponent.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/DragManagerImpl.as
flex/sdk/trunk/frameworks/projects/spark/src/spark/core/SpriteVisualElement.as
flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/supportClasses/GraphicElement.as
flex/sdk/trunk/tools/dependencychecker/frameworkSwcExceptionsList.txt
Added Paths:
flex/sdk/trunk/frameworks/projects/framework/src/mx/core/ILayoutDirectionElement.as
Property Changed:
flex/sdk/trunk/
