2 Replies Latest reply on Mar 13, 2010 7:41 PM by PhyllisCaro2010
    Add rows to and remove rows from a table at runtime question
    PhyllisCaro2010
      I've downloaded an example from Adobe for Adding or Removing a row at runtime.
      The example works great, But it only allows you to generate maximum of 7 rows!!!!!
      I've tried to change the code but I was unseccessful. Can you help?
      Here's the code for the Add button
      form1.#subform[0].Add::click - (JavaScript, client)
      // nTableLength stores the number of XML elements contained in Table1.
      var nTableLength = Table1.nodes.length;
      var nNumRow = 0;
      for (var nCount = 0; nCount < nTableLength; nCount ++) {
      if ((Table1.nodes.item(nCount).className == "subform") & (Table1.nodes.item(nCount).name !== "HeaderRow")) {
        nNumRow = nNumRow + 1;
      if (nNumRow == 7) {
      xfa.host.messageBox("The maximum allowable number of rows is 7. You cannot add any more rows.", "Warning", 3);
      else {
      Table1.Row1.instanceManager.addInstance(1);
