7 Replies Latest reply on Mar 19, 2010 7:19 AM by [Jongware]
    Deleting unused master pages using script
    Muthuraj Durairaj Level 1
      Hi All,
      Is there any possibility to delete all unused master pages in a Indesign document using script?
        • 1. Re: Deleting unused master pages using script
          Yes. You don't mention what sort of script, but I imagine since it's possible with Javascript, it's also possible with the other script languages InDesign supports.
          It's called a "MasterSpread" by the way, which may be the reason you could not find it in the Help.
          Under "MasterSpread" you would have found
          void remove ()
          Deletes the MasterSpread.
          so if a list myUnusedMasterPages contains your unused master pages, this javascript will remove them:
          while (myUnusedMasterPages.length > 0)
            oneMasterPage = myUnusedMasterPages.pop();
            oneMasterPage.remove();
          • 2. Re: Deleting unused master pages using script
            John Hawkinson Level 5
            We could be a bit more efficient.
            For one thing, why waste a variable?:
            while (myUnusedMasterPages.length) myUnusedMasterPages.pop().remove();
            I wish I knew how to construct a list that everyItem worked on...then you could
            myUnunsedMasterPages.everyItem().remove();
            but of course that doesn't work on arrays. Though
            app.activeDocument.pages.everyItem().remove();
            does work, useless as it is.
            I wish there was a way to iterate over everything in an array.
            Here's a horrible solution. It almost doesn't work:
            myUnusedMasterPages.sort(function(a,b){try{b.remove()} catch(e) {}})};
            but sort gets called more than once per item...
            • 3. Re: Deleting unused master pages using script
              Harbs. Level 6
              If you like prototype functions, you can do something like this:
              Array.prototype.removeEveryItem = function(){
                   while(this.length)
                   this.pop().remove();
              and then:
              myUnusedMasterPages.removeEveryItem();
              Of course there's no error checking here, so it's more or less useless as-is for general use...
              • 4. Re: Deleting unused master pages using script
                Hi Jongware,
                Thanks for your quick reply. I forgot to mention that I was looking for VB script. My need is, a indd file has 10 master pages and I hav to keep only two particular master pages and hav to delete rest of the master pages (unused).
                I tried this code as a sample and works fine.
                Set myInDesign = CreateObject("InDesign.Application.CS3")
                Set myDocument = myInDesign.ActiveDocument
                Set myMasterSpread = myDocument.MasterSpreads.Item(1)
                myMasterSpread.delete
                What I hav to do is, I hav to chk for the particular master page names (2-left page_grid and 3-right page_grid and keep them in the document and delete rest of the master pages. I wonder if an For loop will work for this. Or is this possible to call the method which is available on the Masterpages flyout menu "Select unused masterpages" and delete?
                I am not familiar with Javascript. Please help me
                Regards,
                Muthuraj. D
                • 5. Re: Deleting unused master pages using script
                  Hi Harbs,
                  I am not familiar with Javascript and is this possible to get the solution for this in VB script format? Thanks
                  • 6. Re: Deleting unused master pages using script
                    Hi All,
                    I have come up with a solution for this. Below is the VB script code to delete all the masterpages except three which has some specific name.
                    For myCounter = mydocument.MasterSpreads.Count To 1 Step -1
                     If (mydocument.MasterSpreads.Item(myCounter) = "1-grid" Or mydocument.MasterSpreads.Item(myCounter) = "2-left page_grid" Or mydocument.MasterSpreads.Item(myCounter) = "3-right page_grid") Then
                     Else
                      mydocument.MasterSpreads.Item(myCounter).Delete
                     End If
                    next
                    Msgbox "Completed"
                    Is this the right way to do this. Please suggest!
                    • 7. Re: Deleting unused master pages using script
                      It certainly is a way of doing things, and if it works (I didn't try), well, then it works!
                      (I can't see any logic errors; although I am a bit surprised this works in VBS:
                      -- I would have expected a .Name there somewhere.)
