1 Reply Latest reply on Oct 3, 2007 10:18 AM by mightydev
    (Error) URI has a authority component
    mightydev
      i recently uninstalled Flex 3 Builder Beta 1 et AIR Beta 1 for Beta 2
      When i create empty and simple FLEX AIR project, i build and run without problem
      After, i created another AIR project with Colfusion settings and get this error when i click RUN !! :
      Laucnhing toto (time of error: October 3, 2007 11:05 AM EDT)
      Reason: URI has a authority component
      INternal error occured during : Lauching toto
      URI has a authority component.
      Okay, i tried to import a existing projects with COLDFUSION settings and i dont get this error !
      Kinda weird to me and Beta 2 is not better than Beta 1 if im no wrong !
        • 1. Re: (Error) URI has a authority component
          mightydev Level 1
          okay i solved the problem
          From "properties"
          Into "FLEX SERVER"
          Root folder = \\192.168.1.85\wwwroot\Flex\
          Root URL = http://192.168.1.85:8500/
          Into "Flex Build Path"
          Output folder was = \\192.168.1.85\wwwroot\Flex\Toto2CF-debug
          cause this path was taken by ROOT FOLDER field value !
          i changed to M:\FLEX\Toto2CF-debug
          quite strange because this M:\ is same path than \\192.168.1.85\wwwroot\
          And Flex Builder Beta 2 dont want to work properly. You must to change yourself this "OUTPUT FOLDER"
