5 Replies Latest reply on Oct 5, 2007 12:00 AM by Newsgroup_User
    queryAddColumn
      I am having a problem getting this function to work in cf7. My test code is:
      <cfset test=queryNew("col1")>
      <cfset queryAddColumn(test,"col2","varChar")>
      <cfdump var="#test#">
      The result is the following error:
      Parameter validation error for function QUERYADDCOLUMN.
      The value of the parameter 3, which is currently "varChar", must be a interface java.util.List value.
      I'm sure it's something dumb, but any help would be much appreciated
      Fred
        • 1. Re: queryAddColumn
          paross1 Level 2
          Looks like you are missing the array-name. The datatype is optional, so since you have only 3 parameters to this function call, the assumption is that the 3rd parameter would be an array-name.
          Syntax: QueryAddColumn(query, column-name[, datatype], array-name)
          Phil
          • 2. Re: queryAddColumn
            I would like to add the column without populating it. Is this possible?
            Fred
            • 3. Re: queryAddColumn
              cf_dev2 Level 1
              Add it in the queryNew() statement or pass in an empty array (ie ArrayNew())
              • 4. Re: queryAddColumn
                Dan Bracuk Level 5
                quote:
                Fred
                The easiest way is to have the column in the first place. Assuming the query is coming from a db, select a constant, give it an alias, and there's your column.
                • 5. Re: queryAddColumn
                  Level 7
                  It's brilliant. It's simple. It's simply brilliant.
                  Cheers Dan.
                  "Dan Bracuk" <webforumsuser@macromedia.com> wrote in message
                  news:fe4bgl$te$1@forums.macromedia.com...
                  > Thanks
                  > Fred
                  > query
                  > column.
