3 Replies Latest reply on Mar 13, 2010 3:31 PM by John Waller
    Wrong App. Bar in Dreamweaver CS4
    garybrant2
      Hello,
      Really need help on this one!
      I just crashed Windows7 and had to reinstall, along with it my Dreamweaver CS4.
      It's fine except the Application Bar across the top FILE, EDIT, VIEW, etc. has been replaced with
      "menus/DWMenuFile | menus/DWMenuEdit | menus/DWMenuView", AND the pull down for each
      has MANY sub-menus with "Menus/DWMenu" EXTREMELY annoying.
      How did this happen and how can I get back to my "plain vanilla" application bar as I've been accustomed
      to since CS2!
      There's very little help out there for this issue, I WOULD REALLY appreciate anyone that can help with this!
      Thank you!
        • 1. Re: Wrong App. Bar in Dreamweaver CS4
          John Waller Adobe Community Professional & MVP
          Something is very corrupt based on that screenshot.
          Did you clean install Windows 7?
          If so, the only solution I can see is to reinstall Dreamweaver.
          • 2. Re: Wrong App. Bar in Dreamweaver CS4
            garybrant2 Level 1
            I figured it out with some help from your group.
            I had to delete both CONFIG. files which are found under:
            Corrupted file cache
            Dreamweaver creates a cache file called WinFileCache-********.dat or
            MacFileCache-********.dat inside your personal Dreamweaver configuration
            folder (the asterisks represent a series of letters and numbers that might
            differ from computer to computer). This occasionally gets corrupted causing
            instability, unpredictable error messages, and even crashes.
            To solve the problem, close Dreamweaver and delete WinFileCache-********.dat
            or MacFileCache-********.dat. Sometimes, deleting this file is not
            sufficient, and you need to delete your personal configuration folder in its
            entirety.
            I had to actually delete the personal config folder, which rebuilt when I
            relaunched DW, and all is fine!
            It's a great fix, and easy!
            Thank you so much,
            Gary
            Gary Brant, Manager
            140hours® - a Nevada Corporation
            513-ART-SHOW
            • 3. Re: Wrong App. Bar in Dreamweaver CS4
              Good to hear.
              I'm surprised the Config files were corrupt after a fresh re-install though.
