1 Reply Latest reply on Mar 14, 2010 1:08 AM by AdrianWiecek
    swf decompilers
    dhanushkaperera
      i have seen some swf decompilers .i decompiled my flex swfs using those tools and i saw source code of my application .there was some urls i had used for data handling . is it problem for my flex application? i wish someone comment on this pls? thanls
        • 1. Re: swf decompilers
          AdrianWiecek
          I don't know if it's a problem in your application, but you can always load your service URL's from a XML config file at runtime. I think this way they won't be visible after decompilation of your swf.
          But if someone wants to look where your request are sent, it's not a problem. He will just use web debugger like Fiddler and see the outcoming request URL's. But config XML file is a good idea, because your development services are usually on different severs than your production environment. This way you can change your service destinations without recompiling swf.
          Regards,
          Adrian Wiecek
