0 Replies Latest reply on Mar 14, 2010 4:17 AM by jen0dorf
    Template code error
    jen0dorf Level 1
      Hi
      have problems inserting a google map into a template.
      When I do I get the following message:
      You have made changes to code that is not marked editable. If you retain these changes they will be lost
      the next time you apply a template update to this file do you want.....
      It inserts a script code into the head - which is inserted into the instance begin region called head.
      /*wagmp*/
      <?php include("google_javascript/wagmp_map_1.php"); ?>
      </script>
      <script type="text/javascript" src="http://maps.google.com/maps?file=api&v=2&key=ABQIAAAAnuq0K56lajh3gfNNLu3GxhQPsYer20scIhuJe 3lrtkc4-gw_lBScht0raeQ_7yxUannaDm90dRE7pA">/*wagmp*/</script> then inserts a map into the editable area I've called content.
      It
      <div id="wagmp_map_1" style="width: 300px; height: 300px;"></div>
                  <script type="text/javascript" src="google_javascript/wagmp_maps.js">/*wagmp*/</script>
      Thats all the code added I can see and it's all within edit tags.
      What am I mssing?
      thanks
      Ian
