2 Replies Latest reply on Mar 15, 2010 3:42 PM by jerryhamby
    This is getting really old
    jerryhamby
      This is getting really old.
      I keep running into limits on the way I can access information.
      I have some code that was looking at a SerialElement:
      pSerialElement.getChildAt(0).toString();     trace produces "[object VideoElement]"
      Now if I simply store that SerialElement in a MediaElement (pMediaElement = pSerialElement )
      I no longer can do a getChildAt.
      trace pMediaElement = [object SerialElement]   (it says it's a SerialElement)
      trace pPlayer.media = [object SerialElement]
      1061: Call to a possibly undefined method getChildAt through a reference with static type org.osmf.media:MediaElement.
      You encourage us to use MediaElement, yet you lock us out of inspecting our elements
      once inside the MediaElement.
      I want read-only access to the objects inside of MediaElement.
      I should be able to inspect the SerialElement no matter which way it's stored.
      I honestly don't understand the logic, on an open source project, to locking everything down
      so tight with private vars.
        • 1. Re: This is getting really old
          bringrags Level 4
          This isn't an OSMF limitation, it's how AS3 works.  To access the method of a subclass (e.g. SerialElement.getChildAt), you have to cast the object to that subclass, e.g.:
          trace ((mediaElement as SerialElement).getChildAt(0));
          • 2. Re: This is getting really old
            jerryhamby Level 1
            Yes, this type casting you had mentioned before, just didn't stick in my memory.
            Sorry for the late night rant.
            I'm now getting the results I wanted, thanks again for your patience.
            trace(pMediaElement);
            result:  [object SerialElement]
            trace(pPlayer.media);
            trace ((pPlayer.media as SerialElement).getChildAt(0));
            result:  [object VideoElement]
            trace ((pMediaElement as SerialElement).getChildAt(0));
            trace ((pMediaElement as SerialElement).getChildAt(0).resource);
            result:  [object URLResource]
            var vResource:URLResource = ((pMediaElement as SerialElement).getChildAt(0).resource as URLResource);
            trace (vResource.url);
            result:   ./media/walkin.flv
