3 Replies Latest reply on Oct 2, 2007 11:33 AM by Newsgroup_User
    Changing to a different Template
    jgardner920
      My site has many different sections that are each setup to use their own template. Instead, I would now like them all to use the same main template. I am using Dreamweaver MX. Is there a way to specify that every page that had been using template x.dwt should now use template y.dwt? Will I need to update each page individually by detaching from one template and attaching to another? Currently, I have copied my main template over each of the different existing templates so that I have multiple copies with different names. This works, but is cumbersome. Thank you so much!
        • 1. Re: Changing to a different Template
          Level 7
          Do all of the templates have the same editable regions, and are the named
          the same?
          If so, just close all files (after making a backup of the site!), and
          systematically do a find and replace for each old template name to replace
          it with the new template name. The template name appears once on each child
          page in a comment in the head of the page. By replacing it, you will force
          DW to use the new named template. Then open one of the child pages, and use
          MODIFY | Templates > Update all pages....
          Murray --- ICQ 71997575
          Adobe Community Expert
          (If you *MUST* email me, don't LAUGH when you do so!)
          http://www.dreamweavermx-templates.com - Template Triage!
          http://www.projectseven.com/go - DW FAQs, Tutorials & Resources
          http://www.dwfaq.com - DW FAQs, Tutorials & Resources
          http://www.macromedia.com/support/search/ - Macromedia (MM) Technotes
          "jgardner920" <webforumsuser@macromedia.com> wrote in message
          news:fdu02p$3j8$1@forums.macromedia.com...
          > template. I
          > had
          > update
          > another?
          > existing
          > works, but
          • 2. Re: Changing to a different Template
            jgardner920 Level 1
            I just tested this on one small section and it worked brilliantly. I will now proceed with the rest of the site. Thank you, ACE!
            • 3. Re: Changing to a different Template
              Level 7
              You're welcome. Good luck!
              news:fdu2ci$61j$1@forums.macromedia.com...
