0 Replies Latest reply on Mar 15, 2010 10:37 AM by as2 help
    please, help with AS2 / CS3
    as2 help
      In this zip file, I replaced the images, with blank photos, with the image titles, to make it easier to see the problem.
      (download files) http://www.pbsjbuzz.tv/site_flash/site_flash.zip
      (view online) http://www.pbsjbuzz.tv/site_flash
      Thank you !
      Hello, actionscript experts,
      Please, help me, if you have the time. The company that I am doing some flash design work for, bought a template, from templatemonster.com. The template ID that they purchased, is 20643. I usually work more on the design/creative side, but I know a little of simple actionscript. Although, I can not figure out why this is not working, after some simple modifications. I believe that it is an issue with the actionscript, somewhere, in the "pages2/sub_menu2" part or somewhere, in the "pages2/gall_main2" part, in the .fla file. I am 99.99% finished with this site and I would greatly appreciate any of your help, in any way, possible. This site is currently online, for you to view, at your earliest convenience.
      NOTE: (Additional Information):
      Sorry, about so much info!
      This template originally came with 4 main menus (PORTFOLIO / ABOUT US / OUR NEWS / CONTACT US).
      The PORTFOLIO section has 3 submenu links (INTERIOR / LANDSCAPE / ANIMALS).
      I changed the 3 submenu links from, (INTERIOR / LANDSCAPE / ANIMALS), to (AVIATION / EDUCATION / FEDERAL).
      Those work fine.
      Now, I have added 4 additional submenu links. (LEISURE SERVICES / SUSTAINABLE DESIGN / TRANSIT / ARCHITECTURE ENGINEERING).
      So, I now have a total of 7 links, within the PORTFOLIO section, named (AVIATION / EDUCATION / FEDERAL / LEISURE SERVICES / SUSTAINABLE DESIGN / TRANSIT / ARCHITECTURE ENGINEERING).
      My first 3 links work perfect, but the other (4-7) links are not working, correctly.
      They seem to link to the correct category, but do not load correct image, until you click on a thumbnail, then the big image loads, as it is supposed to do, but the thumbnails still have the wrong images loaded.
      I have checked every word for word of the actionscript, but I still can not figure this out.
      I believe that this is a simple solution, surely consisting of only 1 letter, word or sentence of code being wrong, somewhere, in the actionscript, within the flash (fla) file. I have the files, available to download, if anyone willing to help me needs them.
      Thank you, for all of your help.
      My friend looked over the files and sent me this:
      _parent["item"+_root.main_gall_num].gotoAndPlay("s2");
      _root.main_gall_num = num;
      _parent.gall.play();
      Where are those "item1", "item2", defined?
      The functionality of the submenu is fine, but it seems the elements are missing. I tried changing a different "num", and it loaded that
      so i guess you are missing the element on the parent symbol.
      In the main .fla file, this actionscript, is on the first frame:
      Stage.align = "MC";
      Stage.scaleMode = "noScale";
      url = "tfile";
      _root.cacheKiller="true";
      import gs.dataTransfer.XMLParser;
      function onFinish(success_boolean, results_obj, xml) { //This fhunction gets called as soon as the XML loads and gets parsed.
      if (success_boolean) {
      //trace (1);
      play();
      stop();
      var parsed_obj = {}; //We'll use this to hold the parsed xml object (once the XML loads and gets parsed successfully).
      var unCash= new Date().getTime();
      if (_root.cacheKiller=="true") {
      fileToLoad=url+"_main.xml?cacheKiller="+unCash;
      fileToLoad=url+"_main.xml";
      else {
      XMLParser.load(fileToLoad, onFinish, parsed_obj);
      _root.emp.useHandCursor = 0;
      ///forplayer
      _root.mus = 1;
      _root.n = 1;
      _root.num = 1;
      In the main .fla file, this actionscript, is on the second frame:
      function onFinish(success_boolean, gallery_obj, xml) { //This fhunction gets called as soon as the XML loads and gets parsed.
      play();
      //system settings
      // frame number where readMore movieClip is situated
      pagesReadMoreFrame=5;
      // frame number of the first content page
      firstPageFrame=1;
      //system settings
      #include "gs/dataTransfer/xmlFunctions.as"
      //_root.link=_root.getMenuSystemOrder(0);
      In the main .fla file, this actionscript, is on the third frame:
      import mx.transitions.Tween;
      import mx.transitions.easing.*;
      function pic_movs(my_x) {
      var name1:MovieClip = _root.pages.gall.gall.thumbs;
      myTween = new Tween(name1, "_x", Strong.easeInOut, name1._x, my_x, 25, false);
      When the "PORTFOLIO" page loads, this actionscript, is on the first frame:
      _root.main_gall_num=1;
      _root.gall_num=1;
      item1.gotoAndStop(15);
      Each "sub_menu" link (AVIATION / EDUCATION / FEDERAL / LEISURE SERVICES / SUSTAINABLE DESIGN / TRANSIT / ARCHITECTURE ENGINEERING), has this actionscript, on each link, the only difference is the num = 1 (AVIATION), has num = 2 (EDUCATION), num = 3 (FEDERAL), etc, etc, through num = 7, for (ARCHITECTURE ENGINEERING):
      onClipEvent (load) {
      num = 1;
      this.title1.gotoAndStop(num);
      this.title2.gotoAndStop(num);
      on (rollOver) {
      if (_root.main_gall_num<>num) {
      this.gotoAndPlay("s1");
      on (releaseOutside, rollOut) {
      this.gotoAndPlay(_totalframes-_currentframe);
      on (release) {
      if (_root.main_gall_num<>num and _root.gall_animation == 1) {
      _root.gall_animation = 0;
      In the section where the photos load, each frame has a different category of photos that loads on that frame.
      The actionscript, on frame 1, is:
      _root.gall_num=1;
      Then, frame 2 has:
      _root.gall_num=2;
      frame 3 has:
      _root.gall_num=3;
      frame 4 has:
      _root.gall_num=4;
      frame 5 has:
      _root.gall_num=5;
      frame 6 has:
      _root.gall_num=6;
      frame 7 has:
      _root.gall_num=7;
      I added all of the extra images, to the xml file.
      The original xml file came with only 3 categories, of images (12 small and 12 big, in each category).
