2 Replies Latest reply on Mar 15, 2010 1:46 PM by Jacob Bugge
    transform problem
    mindapolis Level 1
      I drew a straight line with the pen tool.  I copied it and pasted it.  I'm trying to rotate it, but it will not rotate.  I checked and none of the layers are locked.  I have no clue what's wrong.
        • 1. Re: transform problem
          Userbak610 Level 3
          If it just that your bounding box is hidden? Try View>Show Bounding Box.
          • 2. Re: transform problem
            Jacob Bugge MVP & Adobe Community Professional
            If you select it (by dragging over it with the Selection Tool or similar), you should be able to rotate it, either with the Rotate Tool or Object>Transform>Rotate, even if you cannot see that it is selected (if both Edges and Bounding Box are hidden), unless you have hit the hidden Freeze button.
            If it is a Freeze case, to Unfreeze, you may try to restart the computer; otherwise resetting the preferences may be necessary.
