4 Replies Latest reply on Mar 16, 2010 3:56 PM by screenname345989487
    OutputClient - a starter qu
    screenname345989487
      I am testing the OutputClient.generatePDFOutput() method, and get the follwoing error:
      com.adobe.livecycle.output.exception.OutputException
      : java.lang.IllegalStateException
      at com.adobe.livecycle.output.client.OutputClient.generatePDFOutput(
      OutputClient.java:149)
      at com.ytzsys.output.TEST.CreatePDFDocument.main(
      CreatePDFDocument.java:82)
      Caused by:
      at com.adobe.idp.dsc.clientsdk.ServiceClientFactory$1.handleThrowable(
      ServiceClientFactory.java:69)
      at com.adobe.idp.dsc.clientsdk.ServiceClient.invoke(
      ServiceClient.java:220)
      at com.adobe.livecycle.output.client.OutputClient.invokeRequest(
      OutputClient.java:607)
      OutputClient.java:132)
      ... 1 more
      Caused by: java.lang.NoClassDefFoundError:
      javax/ejb/EJBException
      at com.adobe.idp.dsc.clientsdk.ServiceClientFactory.evaluateMessageDispatcher(
      ServiceClientFactory.java:587)
      ServiceClient.java:215)
      ... 3 more
      The LiveCycle server is a JBoss turn-key installation on my Windows machine.  The code is basically copied form the API quick start, with a change of the file names only, and is attched below.
      Your help on this problem is greatly appreciated.
      Thanks.
      Kelvin
        • 1. Re: OutputClient - a starter qu
          screenname345989487 Level 1
          Here is the source code:
          * This Java Quick Start uses the EJB mode and contains the following JAR files
          * in the class path:
          * 1. adobe-output-client.jar
          * 2. adobe-livecycle-client.jar
          * 3. adobe-usermanager-client.jar
          * 4. adobe-utilities.jar
          * 5. jbossall-client.jar (use a different JAR file if LiveCycle ES is not deployed
          * on JBoss)
          * These JAR files are located in the following path:
          * <install directory>/Adobe/LiveCycle9.0/LiveCycle_ES_SDK/client-libs/common
          * The adobe-utilities.jar file is located in the following path:
          * <install directory>/Adobe/LiveCycle9.0/LiveCycle_ES_SDK/client-libs/jboss
          * The jbossall-client.jar file is located in the following path:
          * <install directory>/Adobe/LiveCycle9.0/jboss/client
          * If you want to invoke a remote LiveCycle ES instance and there is a
          * firewall between the client application and LiveCycle ES, then it is
          * recommended that you use the SOAP mode. When using the SOAP mode,
          * you have to include additional JAR files located in the following
          * path
          * <install directory>/Adobe/LiveCycle9.0/LiveCycle_ES_SDK/client-libs/thirdparty
          * For information about the SOAP
          * mode and the additional JAR files that need to be included,
          * see "Setting connection properties" in Programming
          * with LiveCycle ES
          * For complete details about the location of the LiveCycle ES JAR files,
          * see "Including LiveCycle ES library files" in Programming
          * with LiveCycle ES
          import
          com.adobe.livecycle.output.client.*;
          import
          java.util.*;
          import
          import
          import
          import
          import
          public
          public static void main(String[] args) {
          try{
          //Set connection properties required to invoke LiveCycle ES
          Properties connectionProps =
          new Properties();
          connectionProps.setProperty(ServiceClientFactoryProperties.
          DSC_DEFAULT_EJB_ENDPOINT, "jnp://localhost:1099");
          DSC_TRANSPORT_PROTOCOL,ServiceClientFactoryProperties.DSC_EJB_PROTOCOL);
          DSC_SERVER_TYPE, "JBoss");
          DSC_CREDENTIAL_USERNAME, "administrator");
          DSC_CREDENTIAL_PASSWORD, "password");
          //Create a ServiceClientFactory object
          ServiceClientFactory myFactory = ServiceClientFactory.createInstance(connectionProps);
          //Create an OutputClient object
          OutputClient outClient =
          new OutputClient(myFactory);
          //Reference form data
          FileInputStream fileInputStream =
          new FileInputStream("C:\\Adobe\\PurchaseOrder_2_pages.xml");
          Document inXMData =
          new Document (fileInputStream);
          //Set PDF run-time options
          PDFOutputOptionsSpec outputOptions =
          new PDFOutputOptionsSpec();
          outputOptions.setFileURI(
          "C:\\Adobe\\PurchaseOrder.pdf");
          //Set rendering run-time options
          RenderOptionsSpec pdfOptions =
          new RenderOptionsSpec();
          pdfOptions.setLinearizedPDF(
          true);
          pdfOptions.setPdfVersion(
          "1.6");
          pdfOptions.setAcrobatVersion(AcrobatVersion.
          Acrobat_8);
          //Create a PDF document
          OutputResult outputDocument = outClient.generatePDFOutput(
          TransformationFormat.
          PDF,
          "PurchaseOrder.xdp",
          "C:\\Adobe",
          outputOptions,
          pdfOptions,
          inXMData
          //Retrieve the results of the operation
          Document metaData = outputDocument.getStatusDoc();
          File myFile =
          new File("C:\\Adobe\\Output.xml");
          metaData.copyToFile(myFile);
          catch (Exception ee)
          ee.printStackTrace();
          class CreatePDFDocument {
          com.adobe.idp.dsc.clientsdk.ServiceClientFactoryProperties;
          com.adobe.idp.dsc.clientsdk.ServiceClientFactory;
          com.adobe.idp.Document;
          java.io.FileInputStream;
          java.io.File;
          • 2. Re: OutputClient - a starter qu
            Jasmin Charbonneau Level 4
            You get a ClassDefNotFound error.
            Are you sure you have all the client jar files setup properly in your application?
            Jasmin
            • 3. Re: OutputClient - a starter qu
              Hi Jasmin,
              Thanks for your quick response.  I have everything in the client-libs/common folder added to the library of my project.  I am thinking the ClassDefNotFound error is thrown because of a class can not be found from the server side.
              On the server side, I only selected the Output module during intallation.  I hope this is not a problem.
              Thanks.
              Kevin
              • 4. Re: OutputClient - a starter qu
                The problem was indeed because of missing jars.  It worked after I included all the jars listed in the quick start guide and the jars in the client-libs/thirty-party.
                Thanks, Jasmin!
