9 Replies Latest reply on Nov 24, 2017 2:07 AM by philippm22666546
    After Effects error: There was an error processing the PDF document.
    Sproketzz
      I have been struggling with this problem ever since CS4 was installed.
      I have the CS4 Mac Master Collection.
      I am using Illustrator to create text for animation in After Effects.
      I can create text in Illustrator and import it into After Effects fine. But when I go to make a change to
      the Illustrator file, even as simple as changing a color, I get this error.
      After Effects error: There was an error processing the PDF document. The file may be damaged or corrupt. (50::29)
      The Illustrator file is then toast as far as After Effects is concerned. It cannot be opened or reimported.
      I have to start over again and over again, rebuilding the Illustrator file each time.
      HELP!!!
