6 Replies Latest reply on Mar 16, 2010 7:26 AM by Harm Millaard
    Playback pixelated
    tarynmary Level 1
      Hi
      I am relatively new to premiere pro (normally a final cut user) however i have been given a premiere file with all the footage etc, my job is to make it look 'pretty' and smooth.
      I have worked on this file before and never had this problem....  Basically when i press play for the playback the HD footage goes really pixelated and blurred.  But when i stop it, it goes back to being very crisp.  The sound is fine. Rendering it also makes no difference at all. Sequence settings are: 720x576 16:9 widescreen DV Pal.  i 'think' i have tried changing the playback settings to high etc and makes no diff - however, i am new to premiere pro so i may have been changing random settings...
      I have tried searching for an answer - and graphic card drivers was the only thing that came up.  I have worked on the very same file before with no probs and i have a brand new imac i5 so i dont think its that...
      Sorry if this is a very simple answer (or operator error!!)...would appreciate some help
      xTx
        • 1. Re: Playback pixelated
          Harm Millaard Level 7
          What is the reason you edit HD material in a SD preset?
          What codec is used in your material?
          • 2. Re: Playback pixelated
            tarynmary Level 1
            Just how it was given me - i think original footage was taken from a small handheld camera not the pro ones.  Also - I think it has been captured into DV... I thought dv was fine to do in sd preset, am i wrong?  I have just taken a screen shot of the sequence settings and the movie inspector of one of the clips used in the project.. hope this helps
            its going to be used on the web ultimately and secondary to be put onto a dvd and get sent to africa (charity project).
            thanks
            xTx
            • 3. Re: Playback pixelated
              Thanks for clearing that up. SD source material in a SD sequence. Nothing wrong here. How does the video look when played on a properly calibrated monitor? The program panel is just for previews and can not be used for quality judgements. You need an external monitor for that. Can you post a screenshot so we can see the degree of pixelation?
              • 4. Re: Playback pixelated
                tarynmary Level 1
                Ah thats alright then.  I haven't got a propely calibrated monitor but have never used one on this project, yet the quality has still changed.  I know the program panel is just for previews but i am just baffled at why it was fine up until now (+2months of working on it)  and now it is not...  Below is a screenshot of the video when being played and tehn when its stopped.  I just find it frustrating to edit when its like this.
                playing:
                stopped:
                Thanks so much for your replies.
                xTx
                • 5. Re: Playback pixelated
                  What it looks like is the jaggies from interlaced material displayed on a progressive monitor. It may be that updating the video driver has aggravated this issue.
                  • 6. Re: Playback pixelated
                    tarynmary Level 1
                    Ah ok - Just worked it out! Had a big update the other day which explains the change. Thanks very much for your help! Really appreciated.
