4 Replies Latest reply on Mar 16, 2010 8:37 AM by Clix websites
    Link not working...??
    Clix websites
      I'm trying to link to an image which will open in a new window using Behaviours > Open Browser Window. When tested in the browser it merely works as a normal link, replacing the first page with a new one with the image on it.
      Here' the code:
      <a href="image-files/red-dawn-bw-b.jpg" title="Red Dawn BW" onclick="MM_openBrWindow('image-files/red-dawn-bw-b.jpg','reddawn','scrollbars=yes,width= 400,height=600')">View larger version</a></p>
      Thanks a lot!
      Josh
        • 1. Re: Link not working...??
          osgood_ Level 8
          Here' the code:
          <a href="image-files/red-dawn-bw-b.jpg" title="Red Dawn BW" onclick="MM_openBrWindow('image-files/red-dawn-bw-b.jpg','reddawn','scrollbars= yes,width=400,height=600')">View larger version</a></p>
          Thanks a lot!
          Josh
          First you need to make sure you have the associated javacript on the page which is needed to open a new browser window. It will be in the head section of your page near the top and should look something like below:
          function MM_openBrWindow(theURL,winName,features) { //v2.0
            window.open(theURL,winName,features);
          </script>
          Secondly if you actually put a link in your anchor tag, which you have done (see below)
          your telling the browser to open a new browser window.
          You should change the link to
          <a href="#" if you only want the new browser window to open?
          • 2. Re: Link not working...??
            Clix websites Level 1
            Thanks so much for that! It's done the trick.
            But I've just seen an extension called Smart Link - accessed by going Behaviours>CB Tools>Smart Link when installed. I'd like to use it so people without javascript enabled can still see the linked image. I've tried it out and do get a new window opening on top the first one but not with the intended image in. It's a copy of the bottom window. Here's the code:
            <a href="#image-files/red-dawn-bw-b.jpg" title="Red Dawn BW" onclick="dpSmartLink('#image-files/red-dawn-bw-b.jpg','redawnbw',600,600,'c:0','sc','r'); return document.MM_returnValue">View larger version</a></p>
            Thanks a lot again, Josh.
            • 3. Re: Link not working...??
              osgood_ Level 8
              <a href="#image-files/red-dawn-bw-b.jpg" title="Red Dawn BW" onclick="dpSmartLink('#image-files/red-dawn-bw-b.jpg','redawnbw',600,600,'c:0', 'sc','r');return document.MM_returnValue">View larger version</a></p>
              Change ths:
              To this
              <p><a href="image-files/red-dawn-bw-b.jpg" title="Red Dawn BW" onclick="dpSmartLink(this.href,'newWin',600,600,'c:0', 'sc','r');return document.MM_returnValue">View larger version</a></p>
              • 4. Re: Link not working...??
                Thanks that's done it - you've been a big help!
