8 Replies Latest reply on Mar 16, 2010 11:12 AM by dtangram
    ItemClickEvent
    dtangram
      I'm trying to display an image by clicking on a link on a LinkBar. I'm using this code in my Actionscript code in Flex:
      private function invoiceClick(event:itemClickEvent):void
           event.label == "Invoicing"
           var image:URLRequest = new URLRequest("InvoiceHome.swf");
      Then, in the LinkBar code, I use itemClick like this, itemClick="invoiceClick(event)". But when I click on the Invoicing link on the LinkBar nothing happens. Could someone, please, tell me what I'm doing wrong.
      Thank you.
        • 1. Re: ItemClickEvent
          AdrianWiecek Level 3
          URLRequest doesn't load the file from the url, it just defines a request. To Load image you can use Loader class or Image class.
          private function  invoiceClick(event:ItemClickEvent):void
               //are you missing if statement?
               if(event.label == "Invoicing")
                    img.source = "InvoiceHome.swf";
          <mx:Image id="img"/>
          Regards,
          Adrian
          • 2. Re: ItemClickEvent
            dtangram Level 1
            I used the image class, but only a blank screen displayed when I tested it. I used the Loader class, but the image still did not load. Here is the code I used. Thank you, I did forget to use the if statement.
                 if(event.label == "Invoicing");
                      var invoiceImage:URLRequest = new URLRequest("InvoiceHome.swf");
                      var invoiceLoader.Loader = new Loader();
                      invoiceLoader.load(invoiceImage);
                      addChild(invoiceLoader);
            Any thoughts?
            • 3. Re: ItemClickEvent
              dtangram Level 1
              Here is more of my code.
              <mx:LinkBar
              id="linkBar" color="#ffffff" x="158.2" y="93.1" width="664" dataProvider="{myViewStack}" borderStyle="none" themeColor="#FFFFFF" fontSize="10"
              height="
              23.95" borderThickness="0" alpha="1.0" disabledColor="#bebebe" itemClick="ntaClick(event), invoiceClick(event)" />
              <mx:ViewStack id="myViewStack" borderStyle="none" width="607.15686" height="30" x="146.8" y="110.7" >
              <mx:VBox
              id="invoicing" x="360.5" y="89.1" label="Invoicing" color="#FFFFFF" fontSize="8" themeColor="#FFFFFF"
              cornerRadius="
              0" fontWeight="normal" width="512.63336" height="24.600002" >
              <mx:HBox width="505.3333" paddingTop="3" height="23">
              <mx:LinkButton id="newin" label="New Invoice" color="#000000" themeColor="#FFFFFF" fontSize="9" click="showTrans(),selectionClick2(event);" fontWeight="normal" width="92.33333" height="20" cornerRadius="0"/>
              <mx:LinkButton id="pend" label="Pending" color="#000000" themeColor="#FFFFFF" cornerRadius="0" fontSize="9" click="myViewStack2.selectedChild=pendingSales,selectionClick2(event);" fontWeight="normal" width="66.66667" height="20"/>
              <mx:LinkButton id="fcs" label="Fax Cover Sheet" color="#000000" themeColor="#FFFFFF" cornerRadius="0" fontSize="9" click="myViewStack2.selectedChild=faxCover,selectionClick2(event);" fontWeight="normal" width="115" height="20"/>
              <mx:LinkButton id="pod" label="PODs Due" color="#000000" themeColor="#FFFFFF" cornerRadius="0" fontSize="9" click="myViewStack2.selectedChild=PODs,selectionClick2(event);" fontWeight="normal" width="78" height="20"/>
              <mx:LinkButton id="inImport" label="Invoice Import" color="#000000" themeColor="#FFFFFF" fontSize="9" click="showInvImport(),selectionClick2(event);" cornerRadius="0" fontWeight="normal" width="112.33333" height="20"/>
              </mx:HBox>
              </mx:VBox>
              </mx:ViewStack>
              • 4. Re: ItemClickEvent
                Sebastien V. Level 3
                There's a semicolon (;) after your if statement. Remove it.
                • 5. Re: ItemClickEvent
                  dtangram Level 1
                  Thank you. I, also, place a period before Loader and I should have added a colon. Here are the corrections.
                            var invoiceLoader:Loader = new Loader();
                  However, after making these changes, my image still doesn't load.
                  • 6. Re: ItemClickEvent
                    Is InvoiceHome.swf in the same folder as class you're loading it from?
                    If it's in for example in assets folder, request should be:
                    var invoiceImage:URLRequest = new URLRequest("assets/InvoiceHome.swf");
                    You should also add event listeners to loader.contentLoaderInfo for Event.COMPLETE to see if loader finished loading with success.
                    • 7. Re: ItemClickEvent
                      Also, check that the swf-loading code is called (by adding an Alert.show( "woohoo") in the if statement for instance).
                      • 8. Re: ItemClickEvent
                        dtangram Level 1
                        Success!!! I found the answer. Here is the code.
                        <mx:Script>
                             <![CDATA[
                                    import mx.events.ItemClickEvent;
                                            if (event.label == "Invoicing")
                                                     myViewStack2.selectedChild=inHomeNew;
                        </mx:Script>
                        <mx:LinkBar id="linkBar" color="#ffffff" x="158.2" y="93.1" width="664" dataProvider="{myViewStack}" borderStyle="none"
                                  themeColor="#FFFFFF" fontSize="10" height="23.95" borderThickness="0" alpha="1.0" disabledColor="#bebebe" itemClick="ntaClick(event),
                                  invoiceClick(event), accountsClick(event)" />
                             <mx:VBox id="invoicing" x="360.5" y="89.1" label="Invoicing" color="#FFFFFF" fontSize="8" themeColor="#FFFFFF"
                                  cornerRadius="0" fontWeight="normal" width="512.63336" height="24.600002" >
                                  </mx:HBox>
                             </mx:VBox>
                        </mx:ViewStack>
                        <mx:ViewStack id="myViewStack2" backgroundColor="0xffffff" borderThickness="2" borderColor="#444444" borderStyle="solid"
                                  x="152" y="143.3" width="962" height="600">
                                       <mx:Canvas id="inHomeNew" width="962" height="600">
                                                 <mx:SWFLoader source="InvoiceHome.swf" x="0" y="0" width="958" height="595"/>
                                       </mx:Canvas>
                        </mx:ViewStack>
                        Thank you AdrianWiecek & NoNick4Me for your replies. I greatly appreciate it.
