0 Replies Latest reply on Mar 16, 2010 7:16 AM by Carol L. Frampton
    [svn:fx-4.x] 14773: Use LayoutDirection constants LayoutDirection. LTR and LayoutDirection.RTL instead of hard-coded "ltr" and "rtl" strings.
    Carol L. Frampton Level 2
      Revision: 14773
      Revision: 14773
      Author:   cframpto@adobe.com
      Date:     2010-03-16 07:16:52 -0700 (Tue, 16 Mar 2010)
      Log Message:
      Use LayoutDirection constants LayoutDirection.LTR and LayoutDirection.RTL instead of hard-coded "ltr" and "rtl" strings.
      QE notes:
      Doc notes: None
      Bugs: SDK-25456
      Reviewed By: Kevin, Jason
      Tests run: checkintests
      Is noteworthy for integration: No
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-25456
      Modified Paths:
          flex/sdk/branches/4.x/frameworks/projects/flash-integration/src/mx/flash/UIMovieClip.as
          flex/sdk/branches/4.x/frameworks/projects/framework/src/mx/controls/ColorPicker.as
          flex/sdk/branches/4.x/frameworks/projects/framework/src/mx/controls/ComboBox.as
          flex/sdk/branches/4.x/frameworks/projects/framework/src/mx/controls/DateField.as
          flex/sdk/branches/4.x/frameworks/projects/framework/src/mx/controls/HScrollBar.as
          flex/sdk/branches/4.x/frameworks/projects/framework/src/mx/controls/Menu.as
          flex/sdk/branches/4.x/frameworks/projects/framework/src/mx/controls/MenuBar.as
          flex/sdk/branches/4.x/frameworks/projects/framework/src/mx/controls/dataGridClasses/DataG ridHeader.as
          flex/sdk/branches/4.x/frameworks/projects/framework/src/mx/controls/sliderClasses/Slider. as
          flex/sdk/branches/4.x/frameworks/projects/framework/src/mx/core/UIComponent.as
          flex/sdk/branches/4.x/frameworks/projects/framework/src/mx/core/UITextField.as
          flex/sdk/branches/4.x/frameworks/projects/spark/src/mx/core/UIFTETextField.as
          flex/sdk/branches/4.x/frameworks/projects/spark/src/spark/components/HSlider.as
          flex/sdk/branches/4.x/frameworks/projects/spark/src/spark/components/PopUpAnchor.as
          flex/sdk/branches/4.x/frameworks/projects/spark/src/spark/components/RadioButtonGroup.as
          flex/sdk/branches/4.x/frameworks/projects/spark/src/spark/components/Scroller.as
          flex/sdk/branches/4.x/frameworks/projects/spark/src/spark/components/VSlider.as
