5 Replies Latest reply on Mar 18, 2010 9:41 AM by victor.turansky
    Sockets not working in v4 Beta for me
    pjc158
      I am using version 4 Beta and have written a simple flex client that uses the socket class to connect to a local .NET Socket Server.
      I can connect to the .NET server but cannot send any data.
      I get no errors or exceptions when running the program.
      I have a policy server running locally which does not seem get a request from the flex client even though I have the following statement before a connection request;
      Security.loadPolicyFile("xmlsocket://10.75.63.237:843")
      var sock:Socket = new Socket();
      sock.connect("10.75.63.237", 4444);
      sock.writeBytes(buf, noBytes);
      sock.flush();
      sock.close();
      I have written both a .NET and Java client and the work fine with the .NET Socket Server.
      Has anybody experience problems with Sockets?
        • 1. Re: Sockets not working in v4 Beta for me
          victor.turansky Level 1
          You must  listen Event.CONNECT event of socket, because  only when socket is connected  you  can send something
          private function connect():void     {
               sock.addEventListener(Event.CONNECT, onConnect);
          private function onConnect(e:Event):void     {
               sock.flush();
               sock.close();
          • 2. Re: Sockets not working in v4 Beta for me
            pjc158 Level 1
            The code provided still does not work.
            Additional information the flex app is being built as an air app.
            • 3. Re: Sockets not working in v4 Beta for me
                   var sock:Socket = Socket(e.target);
                   sock.flush();
                   sock.close();
              May be problem not in the socket.
              And listen error events SecurityEvent.SECURITY_ERROR and IOErrorEvent.IO_ERROR.
              Usually it is Security Error.
              Try this code!
              • 4. Re: Sockets not working in v4 Beta for me
                pjc158 Level 1
                I have tried the alternative code suggested and it still does not work.
                Also I but a break point in the onConnect() function setup using sock.addEventListener(Event.CONNECT,  onConnect) and it never gets called even though I see the connection made in the .NET server.
                Could it be a 4.0 Beta issue?
                • 5. Re: Sockets not working in v4 Beta for me
                  I worked with Sockets in Flash Builder 4 beta 2 and they worked well!
                  What about errors?
                  Did you listen errors in your application?
                  Use try - catch block when you use socket.connect()
                  And what about crossdomain on your server?
                  Could you show your full code?
