1 Reply Latest reply on Mar 16, 2010 11:34 AM by pziecina
    Syntax Error in Dreamweaver
    fadilshamirkhan
      Hey guys. Here I have a .js file with this error in line 20.
      It says  "There is a syntax error on line (xxx). Code hinting may not work."
      Here is the code in line 20....
      for(var i=0,ol=obj.length,val=obj[0];i<ol&&fn.call(val,i,val)!==false;val=obj[++i]){}}return obj;},prop:function(elem,value,type,index,prop){if(jQuery.isFunction(value))value=value.c all(elem,[index]);var exclude=/z-?index|font-?weight|opacity|zoom|line-?height/i;return value&&value.constructor==Number&&type=="curCSS"&&!exclude.test(prop)?value+"px":value;}, className:{add:function(elem,c){jQuery.each((c||"").split(/\s+/),function(i,cur){if(!jQuer y.className.has(elem.className,cur))elem.className+=(elem.className?" ":"")+cur;});},remove:function(elem,c){elem.className=c!=undefined?jQuery.grep(elem.class Name.split(/\s+/),function(cur){return!jQuery.className.has(c,cur);}).join(" "):"";},has:function(t,c){return jQuery.inArray(c,(t.className||t).toString().split(/\s+/))>-1;}},swap:function(e,o,f){for (var i in o){e.style["old"+i]=e.style[i];e.style[i]=o[i];}f.apply(e,[]);for(var i in o)e.style[i]=e.style["old"+i];},css:function(e,p){if(p=="height"||p=="width"){var old={},oHeight,oWidth,d=["Top","Bottom","Right","Left"];jQuery.each(d,function(){old["pad ding"+this]=0;old["border"+this+"Width"]=0;});jQuery.swap(e,old,function(){if(jQuery(e).is (':visible')){oHeight=e.offsetHeight;oWidth=e.offsetWidth;}else{e=jQuery(e.cloneNode(true) ).find(":radio").removeAttr("checked").end().css({visibility:"hidden",position:"absolute", display:"block",right:"0",left:"0"}).appendTo(e.parentNode)[0];var parPos=jQuery.css(e.parentNode,"position")||"static";if(parPos=="static")e.parentNode.sty le.position="relative";oHeight=e.clientHeight;oWidth=e.clientWidth;if(parPos=="static")e.p arentNode.style.position="static";e.parentNode.removeChild(e);}});return p=="height"?oHeight:oWidth;}return jQuery.curCSS(e,p);},curCSS:function(elem,prop,force){var ret,stack=[],swap=[];function color(a){if(!jQuery.browser.safari)return false;var ret=document.defaultView.getComputedStyle(a,null);return!ret||ret.getPropertyValue("color ")=="";}if(prop=="opacity"&&jQuery.browser.msie){ret=jQuery.attr(elem.style,"opacity");ret urn ret==""?"1":ret;}if(prop.match(/float/i))prop=styleFloat;if(!force&&elem.style[prop])ret= elem.style[prop];else if(document.defaultView&&document.defaultView.getComputedStyle){if(prop.match(/float/i))p rop="float";prop=prop.replace(/([A-Z])/g,"-$1").toLowerCase();var cur=document.defaultView.getComputedStyle(elem,null);if(cur&&!color(elem))ret=cur.getProp ertyValue(prop);else{for(var a=elem;a&&color(a);a=a.parentNode)stack.unshift(a);for(a=0;a<stack.length;a++)if(color(st ack[a])){swap[a]=stack[a].style.display;stack[a].style.display="block";}ret=prop=="display "&&swap[stack.length-1]!=null?"none":document.defaultView.getComputedStyle(elem,null).getP ropertyValue(prop)||"";for(a=0;a<swap.length;a++)if(swap[a]!=null)stack[a].style.display=s wap[a];}if(prop=="opacity"&&ret=="")ret="1";}else if(elem.currentStyle){var newProp=prop.replace(/\-(\w)/g,function(m,c){return c.toUpperCase();});ret=elem.currentStyle[prop]||elem.currentStyle[newProp];if(!/^\d+(px)? $/i.test(ret)&&/^\d/.test(ret)){var style=elem.style.left;var runtimeStyle=elem.runtimeStyle.left;elem.runtimeStyle.left=elem.currentStyle.left;elem.st yle.left=ret||0;ret=elem.style.pixelLeft+"px";elem.style.left=style;elem.runtimeStyle.left =runtimeStyle;}}return ret;},clean:function(a,doc){var r=[];doc=doc||document;jQuery.each(a,function(i,arg){if(!arg)return;if(arg.constructor==N umber)arg=arg.toString();if(typeof arg=="string"){arg=arg.replace(/(<(\w+)[^>]*?)\/>/g,function(m,all,tag){return tag.match(/^(abbr|br|col|img|input|link|meta|param|hr|area)$/i)?m:all+"></"
      Now that is a lot of code, so.....where is my error located?
