6 Replies Latest reply on Mar 16, 2010 12:41 PM by Nancy OShea
    background image
    maryn2art3
      hello, I am building one of my firsts websites and I want to put an image in the background.......
      it is tiling, stretching and changing colors..........is this not possible to do.  I am a novice so slowly please. or, if not , a gradient as well, doing the same thing......
      thanks in advance.
      Nary
        • 1. Re: background image
          pziecina Level 6
          Hi
          Not certain what you wish here, do you want a background image that adjusts to the browser size? A css generated gradient? Or none of these, but just a background image?
          For css generated background gradients, (including IE) see - http://www.pziecina.com/design/turorial_demos/background_gradients.php.
          PZ
          www.pziecina.com
          • 2. Re: background image
            maryn2art3 Level 1
            actually ...all of the above.  I am doing a website about a pool  hall .I have a photo I found of pool balls in the background and I would like it to go the entire browser height and width smoothly. If that can not be done I have done a simple gradient that also bleeds into more tiles.............a smooth finish like you were looking at a advertisement.  Thanks!
            Thank you,
            Mary
            Mary Grassell
            Graphic Designer/Web Designer
            COMTek ROTC Support Team
            720 Thimble Shoals Business Center Ste 113
            Newport News, VA 23606
            tel 1:  757-224-0472
            tel 2:  1-866-462-7682
            fax:  757-224-0484
            mgrassell@comtechnologies.com
            The contents of this email message and any attachments are intended solely for the addressee(s) and may contain confidential and/or legally privileged information.  If you are not the intended recipient of this message or if this message has been addressed to you in error, please immediately alert the send by reply email and then delete this message and any attachments.  If you are not the intended recipient, you are notified that any use, dissemination, distribution, copying, or storage of this message or any attachment is strictly prohibited.
            • 3. Re: background image
              pziecina Level 6
              Hi
              Insert the following immediately after your opening <body> -
              <div id="bg">
              <img src="your image ref here" />
              And the closing </div> just before the closing </body>
              then the following in your css -
              body #bg{
                  height:100%;
                  width:100%;
                  overflow: hidden;
              #bg img {
                  min-height:100%;
                  min-width:100%;
              #bg #outerWrapper {
                  height:100%;
                  left: 0;
                  position:absolute;
                  top: 0;
                  width:100%;
              To see this effect - http://www.pziecina.com/indexold.php, (view the code)
              Although on first thoughts this may appear to be a    good idea, the fact that without a large amount of javascript code to work    out the aspect ratio for the image, then apply clipping to the image it does    not offer a good visual impression, on smaller or 'unusually' browser    sizes spoiling the effect.
              PZ
              • 4. Re: background image
                maryn2art3 Level 1
                Not sure where exactly to place the ???  CSS
                body #bg
                #bg img {
                    min-height:100%;
                    min-width:100%;
                #bg #outerWrapper
                Thank you,
                Mary
                Mary Grassell
                tel 1:  757-224-0472
                fax:  757-224-0484
                • 5. Re: background image
                  pziecina Level 6
                  Hi
                  Place this above the </head> tag inside a style block, (which is) -
                  <style type="text/css" media="all">
                  Place the css here
                  </style>
                  PZ
                  • 6. Re: background image
                    In your external stylesheet if you have one (some-filename.css).  Or in code view, within between the <head> and </head> tags in your HTML document.
                    <style type="text/css">
                    CSS code goes here
                    </style>
                    How to Link External Stylesheets -
                    http://alt-web.com/DEMOS/DW-Link-Stylesheet.shtml
                    Nancy O.
                    Alt-Web Design & Publishing
                    Web | Graphics | Print | Media  Specialists
                    http://alt-web.com/
                    http://twitter.com/altweb
                    http://alt-web.blogspot.com
