6 Replies Latest reply on Mar 17, 2010 7:42 PM by Harry Kunz
    How to make a timer?
    TheBrody Level 1
      I'm trying to make a timer..
      When I press a button a movieclip does this: gotoAndStop(2);
      I want it to go back to Keyframe 1 after 10 seconds.
      How can I get this to work?
        • 1. Re: How to make a timer?
          You can use the setTimeout() function to delay a call to a function.
          • 2. Re: How to make a timer?
            TheBrody Level 1
            How can I use that to make it do it after 10 seconds?
            • 3. Re: How to make a timer?
              Have you looked it up in the help documentation?  I am sure it is all explained there for you--absolutely certain.
              • 4. Re: How to make a timer?
                Harry Kunz Level 4
                If you still didn't find what your looking for you can use this:
                import mx.utils.Delegate;
                var nDuration:Number = 10000; //milliseconds = 10 sec
                var nId:Number = setTimeout(Delegate.create(this, myCallbackFunc), nDuration);
                function myCallbackFunc( ):Void
                    trace("Timer Expired with id: " + nId);
                • 5. Re: How to make a timer?
                  TheBrody Level 1
                  Thanks...
                  I got another question though..
                  I have it to when you press a tree (button) it calls a function.. But I have multiple trees that call the function..
                  I want the function to make the timer for just that tree.. I tried this:
                  Button1.onRelease = function() {
                  TreeNum = 1;
                  ResetTree();
                  Button2.onRelease = function() {
                  TreeNum = 2;
                  ResetTree();
                  function ResetTree(){
                       var nDuration:Number = 5000; //milliseconds = 10 sec
                      _root.TheMap["TreeCuts" + TreeNum].gotoAndStop(1);
                  But if I press 1 button then another one before 5 seconds... The first buton won't go back to frame 1.. How can I fix this?
                  • 6. Re: How to make a timer?
                    Harry Kunz Level 4
                    First, place imports always at the top of your codes. You can fix the problem with a queue:
                    var aTreeQueue:Array = new Array();
                        TreeNum = 1;
                        aTreeQueue.push(TreeNum);
                        ResetTree();
                        TreeNum = 2;
                        ResetTree();
                    function ResetTree() {
                        var nDuration:Number = 2000;//milliseconds = 10 sec
                    function myCallbackFunc():Void {
                        var nTree:Number = aTreeQueue.splice(0,1)[0]; //FIFO (first in first out)
                        _root.TheMap["TreeCuts"+nTree].gotoAndStop(1);
