2 Replies Latest reply on Mar 17, 2010 12:47 PM by laxmidi
    Can I Make 2 Remote Calls at the Same Time?
    laxmidi Level 1
      Can I make 2 remote calls at the same time? For example, if I have the following remote objects:
      <mx:RemoteObject id="myRemote" destination="zend" source="MyData" showBusyCursor="true" fault="faultListener(event)">
           <mx:method name="getData" result="getDataListener(event)"/>
      </mx:RemoteObject>
      <mx:RemoteObject id="myRemote2" destination="zend" source="MyData2" showBusyCursor="true" fault="faultListener(event)">
           <mx:method name="getData2" result="getDataListener(event)"/>
      </mx:RemoteObject>
      And I call them at the same time:
      public function myFunction():void {
           myRemote.getData();
           myRemote2.getData2();
      Will it work? Will Flex "confuse" the results of one call with the results of the other call? Do I need an AsyncToken? If so, how do I use an AsyncToken in the above example?
      Thank you,
      -Laxmidi
