0 Replies Latest reply on Mar 16, 2010 4:23 PM by kkfong
    asdoc build failure
    kkfong
      I apologize if I am posting to the wrong forum, or my question does not make sense
      I am a release engineer in a development who is writing flex/air application
      I have no previous experience with flash in the past, and I am asked to generate flex doc using asdoc
      This is the error I am dealing with
           [exec] C:\build\Rim2G\client\RimProjectCommon\build.temp\asdoc\com\amdocs\f
      ramework\components\SimpleFluidListContainerBase.as(150): col: 38 Error: Type wa
      s not found or was not a compile-time constant: Event.
           [exec]                     protected function onResize(event:Event):void
           [exec]                                                       ^
      My question is: where is event type defined?
      Here's my asdoc command line
      asdoc.exe +configname=air -source-path <my source dir> -doc-sources <my source dir> -source-path %FLEX_HOME%\frameworks\projects\framework\src -library-path <my lib path> -library-path %FLEX_HOME%\frameworks\libs\air -library-path %FLEX_HOME%\frameworks\libs -output <asdoc output dir>
      If there's a more appropriate forum for this question, please let me know
      Thanks!
      KK Fong
