1. Re: Deleting the entire file (off the harddrive) of a Bad Take?
Ned43 Mar 17, 2010 10:22 AM (in response to Ned43)i guess the easiest/quickest way is to delete it from your session and edit view then go to "import file" or "save as" then you can find the folder and delete the file you just deleted from MT and Edit view, Audition won't let you delete if it's still using it.
But there should be an option to delete the file directly with two clicks and a command prompt of some sort.
2. Re: Deleting the entire file (off the harddrive) of a Bad Take?
jcs35 Mar 25, 2010 3:27 PM (in response to Ned43)actually no for optimal space saving you should go into the folder with your recorded waves from that session via explorer (just make sure it's the folder from the session you're currently working on, not a backup or different version of that session) and delete the files from there because then you can also delete the "pk" files, where as going into your recorded folder thru Audition via "save as" doesn't give you the option to delete the pk files of the assoicated .wav because they're not visible.
