2 Replies Latest reply on Mar 25, 2010 8:30 PM by fresher4flex
    Conversion of Datagrid to Pdf
    bsagarvidya123
      Hi all,
              please let me know how to convert datagrid to pdf .
      vidya sagar reddy
        • 1. Re: Conversion of Datagrid to Pdf
          Aman_SS
          hi
             i have done the same. Use alivepdf APIs to do conversion. download alivepdf.swc and set  the library path to this SWC. U will get the demo app too there on net. Its easily acheivable.
          • 2. Re: Conversion of Datagrid to Pdf
            fresher4flex
            You can do it in 2 ways
            pdf:PDF=new PDF()
            1) USing pdf.addImage(datagrid_id);
            2)
            var gridcolumnItem:GridColumn=new GridColumn("Item","item",15);
            var gridcolumnLabel:GridColumn=new GridColumn("label Column","label",15);
            var gridArray:Array=new Array(gridcolumnItem,gridcolumnLabel);
            var dGrid:Grid=new Grid(printableItems,15,10,new RGBColor(0xabedea),new RGBColor(0xadedca),
            true,new RGBColor(0xfbbded),1,Joint.MITER,gridArray);
            pdf.addGrid(dGrid,30,50);
            <mx:DataGrid
            x="389" y="233" id="dg1" dataProvider="{itemsCollection}" height="285" width="290">
            <mx:columns>
            <mx:DataGridColumn headerText="Column 1" dataField="item"/>
            <mx:DataGridColumn headerText="Column 2" dataField="label"/>
            </mx:columns>
            </mx:DataGrid>
            here is the Link I got it from
            http://forums.esri.com/Thread.asp?c=158&f=2421&t=302275
