When i try to create a software simulation using automatic recording mode, get the error below:
Unable to locate the element in the application being recorded. Check if the action was performed outside the browser window.
A breakpoint has occurred at script index 2
Click 'Switch To Manual Mode' to continue performing manual actions. Press the designated key to resume automatic re-recording from the next item in the re-recording script.
To skip this action, click 'Continue from next element'.
I am trying to do a simple test using notepad file.
I can create the original project and script file ok.
The problem is when i browse to the saved script file i get the error above.
I am running XP tablet edition service pack 3.
Can anyone help?
Hi there
Are you attempting to use the "Re-Recording Script"?
If so, this probably won't work. I see you are referring to recording Notepad. I think the Re-Recording Script will only function if the window you are recording is Microsoft Internet Explorer.
Cheers... Rick
Helpful and Handy Links Captivate Wish Form/Bug Reporting Form |
Thanks for the reply Rick,
I understood that captivate could be used to re-record actions in software automatically.
I want to record a demonstration of a software application and then repeat in numerous languages using the re-record function.
There is no mention in the user manual that this function is exclusive to internet explorer, (however i do notice the message pop up saying only ie6 is supported).
Any advice would be welcome
Hi again
To my knowledge nothing has changed since this blog post appeared.
Cheers... Rick
