We just upgraded to Frame 9 (from 7.1) and RoboHelp 8. Prior to the upgrade, I was using WebWorks to generate my .hlp files - is there a way to generate .hlp and .cnt files with RH8?
Thanks in advance!
Debby
Welcome to the forum.
WinHelp can only be generated from RoboHelp for Word, not from RoboHelp HTML.
Thank you Peter. Would RoboHelp for Word be compatible with Frame? (I'm guessing probably not.) So, as I see it, my options are:
1. Continue using Frame 7.1 and WebWorks until I can convince our developers to move to HTML for our integrated help
2. Install RH for Word, if it is compatible with Frame - is there any kind of documentation on using a Frame book to generate help files in RH Word?
3. None of the above, do you have any suggestions?
Thanks!
Debby
Are your developers seriously still issuing WinHelp? Put a calendar in front of them showing 2010.
You refer to a HLP file which is WinHelp but WebWorks sounds like a tool for producing web based help formats. You do mean WinHelp?
No RH for Word does not work with FM.
LOL about the developers, didn't know you had met them.
WebWorks was actually packaged and integrated with Frame 7, and is a Windows help file tool. (I just use it, didn't name it :o). It generates .hlp and .cnt files. The .cnt files can be opened and edited directly with Microsoft Help Workshop.
Do they realise that under Vista and Windows 7 your end users have to download the viewer for this type of help? They cannot distribute the viewer.
Sounds like you are stuck with FM and WebWorks.
Yes, they do know that - I had to add a blurb to our ReadMe files for that!
Thank you for your feedback - I appreciate your time.
Hi there
Sounds like you are creating 32 bit WinHelp files. If you want to switch to 16 bit WinHelp files, the viewer is already present on Vista and Windows 7, so no download would be needed and WinHelp would still work.
Whether WebWorks allows you to choose between 16 and 32 bit WinHelp files is another matter... Rick
Helpful and Handy Links RoboHelp Wish Form/Bug Reporting Form Begin learning RoboHelp HTML 7 or 8 within the day - $24.95! |
Thanks, Rick.
The problem is that newer versions of Frame have replaced WebWorks with RoboHelp, and RH creates html help rather than WinHelp.
Debby
I have the same issue with WinHelp, except that I am starting with a Word file. I have TCS2, but I don't see the any RH for Word. Am I out of luck?
Ben
Ben
When you installed TCS2 there was an option not to install RH for Word, sounds like you took that option.
There is a TechNote on Adobe's site covering how to add it later as you don't get the option if you reinsert the disc. You might want to uninstall and reinstall to get that option.
Check first in Program Files. Look under Adobe > TCS and see if you did install RH for Word. It's possible you did and then deleted the icon.
HI Peter, I checked the Program Files and it's not there. Looks like I'll be re-installing. Happy that I don't have to revert to an older RH version though. Thanks!
It looks like you will be able to resolve your issue. In my case, I will
have to look to products other than Adobe in order to fulfill our
obligations.
Hi Debby
I'm assuming that if you have Frame and RoboHelp you are using the Technical Communication Suite? (TCS) If so, you should have RoboHelp for Word available. However, I'm not sure how that works. Is Frame capable of producing a Microsoft Word document or RTF file?
Cheers... Rick
Yes, Rick, I'm using TCS. RH for Word was not installed, but I can hunt down the install DVD from our IT group to get it.
Frame cannot produce a Word doc, but will output an RTF file. So if I am reading between the lines correctly, you're suggesting to output from Frame > RTF and then import the RTF back into RH for Word to compile the help files?
Debby
Hi Debby,
I think that would work. I just uninstalled/reinstalled TCS2 and included RH for Word. I'm going to try in a few, but, in the meantime (it took about 3 hours to uninstall/reinstall TCS2), I was able to use Doc-To-Help on another computer to generate .hlp files.
This thread helped a lot! Thanks!
Multiple calls to Adobe support have been unsucsessful in resolving this. We can't be the only company that has upgraded from Frame 7.1 (with WebWorks Pro integrated) to Frame 9 with RH8.
Has ANYBODY out there faced this? What did you do?
TIA-
Debby
Those are from WinHelp, which is really old - I don't think any new help builder package generates it anymore. You can import old WinHelp projects into RH8 to convert them, but they aren't a Single Source Layout anymore to be generated.
I believe WebWorks did support the HLP output but it has never been a RoboHelp HTML output. RoboHelp for Word still produces this format but, as Jeff says, it is dated.
Hi all
And I'm doubtful that Frame or RoboHelp for Word have any sort of connection. That's what is really needed here. An ability for RoboHelp for Word to pull in a Frame document in order to regurgitate .HLP format.
Can Frame create a DOC file?
Cheers... Rick
FM9 can produce an RTF file that Word could pick up, but I'd be thinking about changing my help output if all my source docs were in Frame. Seems kind of kludgy to go FM > RTF > Word > RH for Word > WinHelp when with TCS2 you could go FM9 > RH8 HTML > WebHelp/AIR/CHM/FlashHelp relatively painlessly <grin & wink
