0 Replies Latest reply on Aug 24, 2007 2:56 PM by jpaulodesigns
    need help creating buttons to control xml slideshow
      I am a complete novice when it comes to using the scripting Flash... basically I have a setup that works perfectly for how it is setup... basically it's loading images into 2 different containers (I believe) and then uses swapdepth to switch them and they are loaded from a .xml file. I need to create buttons (basically foward and back) to go through the images... actually what needs to be done is just have it load the initial image like it does, but not go into a slideshow, i just want the user to use the left or right arrow to call up the next or previous image... i apologize for the long paragraph, I just want to make sure I explain it correctly... below is a copy of the code that is used to operate the slideshow...thanks in advance...
