1 Reply Latest reply on Mar 17, 2010 3:07 PM by Ben M
    XML problems
    jukatiger
      I am teaching myself Flash and Dreamweaver by taking apart templates that I download and trying to rebuild them and change things.  I have a flash SWF that has pages where the content is loaded from a single .xml file.  When I put a link for download with in the text on the xml it shows the hand to click but when I do nothing happens.  Also when I do a preview in Flash of the website and click that link it works fine.  I can't figure out why this won't work when I run the .swf through a .html and look at it from a browser.  Thank you for any help you can give me
        • 1. Re: XML problems
          Ben M Adobe Community Professional
          First off I would recommend making this post in the Flash forum if you have not done so already because I have a feeling you will need to go back to the AS file to make the fix.  From the description of your problem I would suspect a path issue, but I cannot be 100% certain without the code.
